Spinners?
virtvic
The Cabaret King
21 (96%)
2,012CR
What's the cheapest way to get a spinner in mame? The ultimarc ones are REALLY expensive?
Are there any usb alternatives or is the better way to use an arcade spinner and an optipac?
big10p
Coins detected in pocket!
6,071CR
I've seen people hack an old mouse before, if you want cheap. I used to have an ultimarc USB spinner but found the slight lag to be too annoying, so sold it on. Newer makes/models may be better. Not sure if the lag was due to the USB interface or MAME though, TBH.big10p2019-02-18 13:11:33
minwah
238CR
Luigi
72CR
I have a small pcb with USB where you can connect a regular spinner. I used it for testing some spinners but it was never used in a cab. I can take a photo if you're interested.
Ropi Jo
127CR
I've used the mouse hack to add 2 x USB wheel-mouse spinners to mame. It seemed the PC sometimes lost the location of the mice and it was a pain to get them working again. I re-worked it to use a single mouse with the X axis to one spinner and the y axis to the other. This worked better, but still got issues with the PC 'losing' the mouse. This was probably made worse as I also had a PS2 trackball that was seen as another mouse. Plus, the massively over-populated CP was awful.
My new in-progress build is using an opti-pac to handle all spinners and trackballs on inter-changeable CPs, so will hopefully be more stable.
Ropi Jo2019-02-20 14:13:25
