Splitters ! :(
Evening all,
Have been working on my chewlix cab getting the controlls sorted for consoles and pc etc.
When wiring up for the ps3/4 I decided to go with a pair of Brook UFB, always used these in my fightsticks and never had problems (For the PC I’m using a jpac so I can keep the original loom in place)
I have the Brooks in the control panel, everything works great but the thing I’d like to avoid is the need to open the Panel when switching from ps3/PS4.
What I’m looking for is a USB switch, in an ideal world it would have 4 inputs, 2 outputs and work on two channels. That I realise I’m unlikely to find - If not then 2 in 1 out would be workable.
The thinking here is to run P1 ps3 and P1 PS4 usb cables into the USB switch and pass the signal through to the P1 brook board. When switching consoles rather than opening the CP and changing the cables over as I do now I would just switch the channel on the USB switch (I will also need to replicate this for the P2 brook board and cables hence the search for a 4 in 2 out 2 channel)
If anyone knows of anything/ any alternative solution to switching out the cables it would be much appreciated.
In addition to this I’m looking for a HDMI switch that actually works ;) I’ve tried a bunch of the ones on amazon and none of them seem to do the trick which for 30 quid I can’t really expect, the hdmi switch needs to have a separate audio out :) this may need to be a bit more of an expensive purchase, one thing I’ve seen that I’d like to ask if anyone has experience of is this - https://www.futureshop.co.uk/blustream-4-way-4k-hdmi-switch it’s a bit expensive but the price is not an issue if the damn think works!!
Anyone have any experience of something from bluestream???
Many thanks for your time and any advice will be greatly appreciated.
Happy gaming !
J
Red - Brooks (cables run to the consoles in the cab)
Green - original loom connectors
Blue - Brook loom connectors (I switch these out when going from pc to consoles, this is easy as it sits at the front of the CP, if I could eliminate having to do that though... :) )
When it’s up and running
