Star Wars Matrix Errors
Stickman
355CR
Morning all
You have to love this hobby, I have just received the last part of my Star Wars upright (Coin Door) to compete the restoration, was ready to type it up and post!
So I turned on the machine for a few games and I am faced that once I start in game there are no stars or Tie Fighters and occasionally I get a flicker of the death star.
So first things I run the self test and I get matrix errors. Reading up in the troubleshooting guide I see that we have tests 17 through 20 fail and also accumulators A to D. Looking at the test results it is reporting incorrect upper and lower bytes, I also get the odd character flicking between say the A and what looks like a B, which I guess is as the tests are being run x times a second. There is a picture of the errors below. It also gives different values (same tests fail) when I have run the self test again.
I checked the voltages and they are at 5.02v at the board and I also pulled the boards and re-seated all IC's
Did lots of googling and a lot of time people suggest the PROM's in row 7 being the most common cause. I am going to get the probe out and start to try and work though it but any pearls of wisdom, advice greatly appreciated. My logical (or none logical) brain says I need to look for something that would effect lower and upper bytes so is common to both.
I want to have a stab at getting this sorted myself before I dig into my pockets and send off to get repaired.
Just as a side note this was repaired about a year ago by Equites who did a sterling job bringing it back to life as it was dead, so it has a new AVG for instance. (maybe heading back his way!)
Thanks all.
7,230CR
Obviously test your voltages and all socketed chips first.
Interesting read here , Not saying its your issue but worth a look.
https://forums.arcade-museum.com/archive/index.php/t-303126.html
Hope this helps,
Dave.TheDaddy2020-06-03 15:56:26
Stickman
355CR
Thanks Dave, I have read that post several times along with the guide in front of me so I can start to get my head around it.
I think I will try to get the PROMs first and take it from there.
Stickman
355CR
ok, so armed with a logic probe, having had another good read of the guide and troubleshooter I went to start poking around, starting with the 4 PROMs at 7H, J,K L and was expecting to get the following.
According to the post from another forum
The instruction PROMs in row 7 are all fed the same ten inputs MPA0 thru MPA9 coming from the Matrix Processor Address counter at 6H, 6J, 7P and 8N. So pins 1-7 and 15-17 will be the same for all four chips. The outputs of each of the chips (on pins 11-14) will not be the Same.
So with the game on, I probed and got the same across all four PROMs on pins 1 thru 7,15 to 17, tested outputs and AHA one output is stuck low on pin 12 of 7K.
Now this is not an original Atari chip so looks like it has been swapped out before, See picture below.
Is it really going to be that easy for me, surely not!
So next job is to get a replacement, I could go down the route of getting an IC and blowing the PROM or see if I can source a preprogrammed one. Nad do you have any?
Stickman2020-06-03 20:01:25
Stickman
355CR
thanks for the tip, I will get some, I have added two small fans that blow up through the pcb cage to help as part of the restoration I have done that hopefully also help.
Stickman
355CR
I was thinking if I can track down replacements I may create a spare batch, maybe overkill. Not sure my eprom blower does these either could not find the listed alternatives in the selection drop down. That said i5 is a cheap thing.
Working on getting a replacement and will order heatsinks tomorrow
Fingers crossed it fixes it.
Equites
Chief Sheesher®
35 (100%)
3,329CR
Working on getting a replacement and will order heatsinks tomorrow?
You should be able to read it with an eprom burner if you can make up an adaptor, then simply verify the contents against Romident.
Equites
Chief Sheesher®
35 (100%)
3,329CR
TheDaddy said:
I would remove the sticker first and put a bit of heatsink compound on. Wont transfer heat with sticker like that.
Hope this helps,
I think Simon has simply plonked the heatsink on as an example not a permanent solution.
Zektor
312CR
Hope this helps,
Its not fixed on, that was just an example of the size :)
bbz149
26 (100%)
1,608CR
I would get larger Heatsinks, I use these on OW! you can get smaller ones which will cover the entirs Chip! CPC sell them and sure RS will have them also
bbz1492020-06-04 08:59:41
Equites
Chief Sheesher®
35 (100%)
3,329CR
I've had a good look at the schemes and the PROM at 7K, pin 12 should be LO.
So, looks like your problem is elsewhere.
More likely logic failure somewhere.
Equites
Chief Sheesher®
35 (100%)
3,329CR
Stickman said:
no do not think so, that said you have me thinking will fire it up later and check
If the Score and Wave number are missing your Green is gone. Check the middle small black D shaped transistor on the AVG board near the edge connector if so. These can break the pins if handled a bit.
They are silkscreened Red, Green and Blue.
Equites2020-06-05 21:00:51
