Star wars - questions/scope
DaveR
367CR
Hi
We still not got our Star Wars up and running, we had issues with deflection boards where one side is not starting up - however now we at a point where both deflection boards not doing much
Spot Killer is on
Game is fine... runs on 4.6V ??
Changed Big Blue recently to something reconmended on the cap list here.
Firstly I would like to check that its all working as it should on a scope? is that ceter point triggering the spot killer?
https://youtu.be/uE598cQuMG0
Mitchell Gant
888CR
Hi,
That scope image looks perfect to me, as you've not got blanking hooked up you'll see all the retrace lines back to centre.
On the Star Wars title screen (2nd pic) you can also see the 3D "zoom focal point" for the scrolling text near the top centre, that's just how the software draws that screen, so you see a lot of centre point to focal point, then on to the Star Wars text image. The actual Star Wars letters are built up from several chunks of image too, and not individual S, T, A, etc. letters as you might think.
Some 'scopes do have a 'Z' input for blanking but IMHO it doesn't just connect up to you Star Wars/Asteroids/etc board and work like a proper vector monitor.
Yes you can get some TTL boards to run down to 4.6V It's not likely to be 100% reliable at that voltage though!
DaveR
367CR
oh i see thanks
next stop is back to deflection... .i was just checking that the game board was indeed fully doing its job.
one side of deflection is warm and the lower left side is cold, spot killer on
does neck glow look quite amber compared to modern tubes ?
Just had BOTH 5amp SB of deflection go after leaving for a while
the one starting the get to me lol
lix
546CR
Doesn’t look like the stars are being rendered so likely there’s a logic chip fault in the math box circuit which handles 3D calculations, or it could be the random number generator circuit, although I think if that’s blown you’ll still get stars in straight lines.
Lack of stars shouldn’t trigger the spot killer though.
I’ve had bad junctions in the crimps on the molex plugs to the deflection and power transistors, dry solder joints on the header pins and bad transistors. If it’s blowing fuses then I’de check for shorted transistors, either internally faulty or might be the case or pins shorting to the metal chassis frame (if it’s a WG6100?).
ColinD
6 (86%)
1,367CR
I'd suggest that you follow this guide initially.... Gavin and Myself have spent some time on this in the past.
http://www.ukvac.com/forum/vector-arcade-machine-pre-flight-checks_topic340667.html
It's fairly important that you follow this through step by step and don't miss anything out. This will help diagnose any potential issues.
ColinD2022-07-22 19:55:19
