I spent ages (months) bringing a Star Force PCB set back from the dead last year. It was a pain because of the total lack of schematics, and I had to reverse engineer loads of things. However, one thing I did notice is that the architecture of the circuit is very similar to Bomb Jack - not surprising, since they're both from Tehkan. Bomb Jack schematics are readily available online. There were loads of faults on my board, but here's the section of my repair log relevant to the background tiles:
Looking at background graphics, it seems that there's something wrong
with the tiles. What should be black or just stars has grey/pink
landscape parts all over it.
Flickery pink mess is strongly affected by applying fingers to EPROMs
on board C. Address bits A5, A6, A12, A9, A11, A10 all floating.
They seem to come from latches P5, N5 (74LS273). Piggybacking them
helps. Replace both. Background tiles are now correct but somehow
displaced horizontally and vertically and scrolling is not smooth.
Character layer is still a bit scrambled and sprites are only showing
every other line.
Both tile layers are offset to the right by the same amount.
Tile RAM seems to be N4. Trace A7, pin 1. Goes to L3 (74LS157) pin 4.
Pin 3 seems to go to row counter, pin 2 to CPU address bus. Pin 1 selects
'counter' 32 times per video line.
Counter (bit A7) comes from 74LS273 at H3, pin 19.
H3 pin 18 also goes to K3 (74LS273) pin 18 and K2 pin 10 (74LS283)
K2 is an adder. Piggybacking J2/K2/L2 makes no difference.
Pins 3 and 5 of K3 are stuck high. Forcing them low pulls the tiles
in the right direction.
K3 pin 3 comes from K1 pin 15 (74LS273). Seems to be working.
K1 pin 14 goes to H1 pin 6 (74LS08) which only seems to be a buffer.
H1 pin 5 goes to F1 pin 4 (74LS245). Gets gated once per frame. Piggybacking
doesn't help.
N4 address bits:
A0 8 N3/7 6
A1 7 N3/9 10
A2 6 N3/12 13
A3 5 M3/4 3
A4 4 M3/7 6 H3/12
A5 3 M3/9 10 H3/15
A6 2 M3/12 13 H3/16
A7 1 L3/4 3 H3/19
A8 23 L3/7 6
A9 22 L3/9 10 GND
A10 19 L3/12 13
Why is L3/10 grounded? and N3/3 high? They're wired that way.
Having removed L3 and N3 to investigate, put them back. Picture has gone
odd with a blanking problem. Discover that a mod wire from 60-way connector
has come adrift and is contacting the wrong place. Discover also a broken
track underneath it. Deliberate? Remake it. Lots of random-ish tiles appear
in places they shouldn't. Not good.
Things don't look quite right around RAMs H2/F2. Replace F2 and background
tiles are now correct, though text layer is still thoroughly scrambled.
Also, I have a note that IC L4 (74LS245, I think) on board C is the data buffer to the tile RAM.
I hope this is some help. It's not going to be easy without the schematics. But good luck - it's a great game!
Chris
