Stargate RAM 34 error (just checking)
Judder
1,009CR
Hi everyone
New Year, New resolutions, so powered-up the Stargate/Defender machine yesterday with the Stargate board set installed and it went into a 1-3-4 error on ROM board, with corresponding RAM error 34 message on the screen.
Leaving it to reboot for a few hours, sometimes it would run a bit, then crash, other times just crash during initialisation.
So I replaced RAM chip row 3, 4th from the left (as per schematics labelled 3U [34]) and the same error occurs.
To test the logic, I removed the RAM chip at 32 (as per schematics labelled 3S [32]) and the error moved to 1-3-2 with a RAM error 32 on the screen [good news].
So.. if seems that it might not be the RAM chip, but perhaps the socket the chip is going in to.
Any thoughts on which way to jump (guessing removing 33, testing and checking that moves there, but that would be a similar test to 32 above)?
Maybe re-soldering a new socket might be the way to go (but probably voltage testing 34 first to check the +5 etc.)
Good thoughts on that here from YellowDog
http://forums.arcade-museum.com/showthread.php?t=96860
but would appreciate if anyone has more advice on what the most likely part of failure might be
tb lilley
5 Star
1,686CR
In respect of potentially dodgy RAM sockets I usually find it worthwhile to do a quick continuity check from the pins in the socket to where the pins are on the solder side. If a leg/pin doesn't pass continuity you might get away with a quick reflow - otherwise replace the socket. Those Williams RAM sockets are pretty poor quality.
Judder
1,009CR
Thanks tb
Yes I'll try that - also wonder if there might be a broken/old leg in the socket from when I replaced all the memory - I'll check that too.
Just realised your profile picture is the guy walking along the beach with the drink (can't remember the brand) - cool advert
andyman
1,059CR
Southern Comfort
Yeah, as above continuity check socket, check for the 3 voltages at each corner, if all else fails replace the socket. As the error moves, doubt whether its logic related.
Judder
1,009CR
Thanks Andy
Yes moving error = good thing
- will try the tests as above and report back
How's your Defender coming on back to life BTW?
