Startrek TNG multiple errors
VicN
1CR
I have a Star Trek TNG, normally in working order, today my 9yr old grandson asked to play on it, as I leaned down and flicked on the switch underneath he started pressing the firing trigger repeatedly. Three balls all popped up but non fired, I managed to get the balls out by pushing them up the ramp with my finger and put them back in the machine, turned it back on and it did the same thing.
It then tells me various switches are stuck closed such as 'GND short row 1 is stuck closed. left flipper stuck, right flipper stuck etc
I opened the door and locked in the safety button to do some tests but it goes haywire and rapidly runs through the settings but won't let me stop on anything.
As this is a wide body machine it also preloads some of the ball ejectors using runways under the deck, if any are not located it starts cycling through the coils in an attempt to dislodge a stuck ball.
Any ideas what happened here ?
Bobbdobalina
146CR
I’ve got a sttng. It’s an awesome pinball but also one of the most complicated from that era. You may be better to ask on pinballinfo . There’s some very knowledgeable and helpful pinball guys on there who I’m sure could help you.
Hope you get it sorted.
VicN
1CR
Thanks guys,
I did see a fleeting message about a fuse on the display as it was going through the error list but can't seem to find it now. I'll have another go & hopefully it could be that causing the problem
Spadge
172CR
Had 7 years collecting pins inc stng and especially for the BW era, most faults were fixed with fuse changes. Most are on the head unit, easy to change. A multimeter is nice but not required. Tons of info online but get a williams/Bally fuse set and keep it in the coin box.
If you aren’t a member of pinballinfo then STOP and register now. Full of generousity and knowledge. A great community.
J69
281CR
Do any of the solenoids fire in the test screen?
Check one of the following fuses isn't blown in the back box
F101
F102
F103
F104
F105
F112
Fantazia2
2,246CR
So you're saying that sometimes it probably is "Just a Fuse"?
simonden
20 (100%)
1,042CR
On my STTNG it actually was just a fuse. I had an issue where the ball was circling and subway divertors weren't working, tested all the subway coils, tested the top drop up and drop down coils, all fine. Suspected the Aux 8 PCB all fine. Turned out to be F103. Replaced fuse and it is playing happily.
BUT it is still best to test the coils the before replacing the fuse as if one is shorted I guess it could be possible for it take out the aux8 or driver board?
Spadge
172CR
In my experience of collecting BW machines, yes in general.
Obviously there are many things that can be awry, but in most cases the fuse in question was a problem - if a solenoid was locked on it’s very likely that it would blow again and something was shorted.
Wire off/shorting/Fuses were my first check. I’m not a field engineer just passing on feedback based on ownership experience.
Bobbdobalina
146CR
Don’t think this is related to yours but when I got my sttng it did all sorts of weird sh*t. Kept shooting balls out and not finding their location under the play field diagnostics were all over the place .
My problems were battery damage to the cpu, trough opto and flipper button opto.
I think the amount of optos on the game make it troublesome and there’s also a mod that prevents damage to the driver board that is also recommended.
redleader
50CR
i think so aswell, battery damage.
had this on my Twilight Zone, i had to repair board and now i have batteries off
the board to prevent any damage in future.
VicN
1CR
The batteries I removed were not leaking though and still had enough life to keep track of the settings.
It's looking more likely to be a bridge rectifier, one of which affected the flashers was replaced 5 years ago but not sure I can risk doing it myself
