Starwars Mathbox error degaussing
dulstone
22CR
Now starting work on renovation of my starwars cockpit.
Firstly, I have an amplifone 25" XY - picture OK but now rainbow coloured around the edges. I checked the degaussing coil - it does get a voltage briefly on startup which disappears when the posistor warms up but only seems to be a few volts, and looks like it should get 50v. I measure 50v OK just before the posistor. I can't find an exact match posistor but have a couple of others similar - resistance looks to be a bit different - should I swap it out ?
Secondly, now getting a matchbox error, pictures below. Result is that much of the action, including the star field are stuck in the middle of the screen. I swapped out the matchbox proms but same result so seems to be surrounding supporting circuitry fail rather than proms. Any advice - I can solder/desolder/replace chips but my ability to trace and diagnose is not there! Would be happy to pay someone to take the repair on!
Rob.
Pictures below of Mathbox problem (before degaussing packed up!)
dulstone
22CR
Board repaired by Mark @ retroclinic. Degaussing problem was in fact purity - just needed to move the yoke back a little.
The force is now with me !
Rob.
