Steering problem outrun 2
Brettster
1,276CR
Is there a way to reset / Center the steering wheel on an outrun 2 cab?
Looking in the test options I can set a number between 0 and 255 so I set this at 127
But either this car veers to the right all the time or there's no left turn until it's all the way left
Could this be a broken 5k pot?
Outrun2
Colonel Outrun
1,181CR
Could be a broken or sticky pot.
Go into the I/O test and and check what the value on centre of steer is - should be 80H IIRC. Then move the wheel left and right to see if the values move smoothly.
If the centre of steer is off you're best pulling the dash out so you can get to the pot. There's a screw on the bracket that allows you to angle the pot out the way while you centre the steering wheel. Rotate the pot until it registers about 80H then move it back so it meshes with the wheel shaft gear - making sure the wheel remains centred.
Tighten up, secure dash back in place and job done.
Brettster
1,276CR
Thanks for that :)
I pulled out the dash, and loosened the retaining screw, moved the pot out of the way and got the test up, could see the numbers moving one way but very erratic the other, so I pulled out the Pot and connected up my Multimeter.
Pot was working fine, from 0 - 5K nice and smooth.
I opened it up and cleaned it out anyway and rebuilt it, popped it back in the cab. tried to set the middle point at 80, but there was nothing happening!! tested the pot again with the meter and working. jiggled the wires at the back of the cab under the monitor and it started working.
lined up the wheel and put the dash back in , stopped working. aargghh!!
Took the dash out again and unclipped the pot cable under the monitor and reseated it
now its working great :)
but the wheel is slightly off centre still, looks like I'll be pulling the dash out again for more adjustments lol
bbz149
26 (100%)
1,608CR
Could just take the back of the Cab off and adjust it from there
