Steering wheel removal
G
Guests
Guest
So how does one go about removing this steering wheel...?
ZedEx48K
8-Bit
1,424CR
You need to remove the wheel and the plastic casing first, once they are off and it's just the shaft you then remove the 4 nuts on the inside, it should then slide out.
G
Guests
Guest
Ah ok does the center cap on the wheel come off? i presume there is a nut under there to remove then you take the wheel off and the shaft will slide backwards out of the panel?
ZedEx48K
8-Bit
1,424CR
I think there is either a nut or 3 screws underneath it into a circular block, it's been a good few years since I sold my RR so my memory is a little rusty, but the inside of the panel is a fairly generic steering mech that I've used a few times and just pulls out, shouldn't need to touch the pot.
Oh to add, I've seen it where the nut on the inside has snapped clean off with part of the shaft still in it while trying to losen that end
ZedEx48K2016-09-24 20:52:11
G
Guests
Guest
Ok great thanks, any idea how to get the center cap off? i could use a screw driver and pry it off but i don't want to mark the plastic if i can help it.
Let's hope mine doesn't do that!! haha
bonehead
I'll get pix tonight
50 (100%)
1,729CR
You have to prize it off. These things are made for arcade use so don't worry too much about it they are robust. Just look how the cab is bolted together and go for it. Take pictures if your not sure so you know how it goes back together.
It's easy to do.
