Wow that’s a mess! Could well be stuck together with solder or glue even. Or maybe just stuck with corrosion. If I were you I’d check voltages/continuity while it’s all together. And repair/bypass the pin while it’s in place too.
Or failing that if your quite techni-capable cut that mess out completely and attach a new edge connector and make a new converter/adapter. Might not be possible to desolder all the wires from the edge connector without causing damage though.
