Stupid question
Rawsome
lost my cab cherry
72CR
How do I remove the marquee from a Zaccaria Scramble? I don't want to snap or break anything.
Thanks.
PaulSwan
ZZZ
1,117CR
At the back of the cab there is a sloped wood panel above the back door secured with 4 bolts. The bolts have wing nuts (usually) that you have to CAREFULLY reach behind the monitor surround cardboard to get at to undo (i.e. stick your whole arm up there). With that out, you can get at the marque light assembly and remove it. Then you can get at the nuts that secure the top and bottom of the marque. See...
http://www.zzzaccaria.com/MrDoRestoration.htm
...for an idea, and how to get out the marque if the carriage bolts are seized.
Paul.
Rawsome
lost my cab cherry
72CR
Muchos thanks Paul!! I was inside the cabinet doing a fine contortion act! I did see those bolts but wasn't sure to mess with them until I found my wd40 as they are very corroded
I am inside now, and the last part of the cab has been declared a spider free zone thanks to Henry.
I've also dismantled the cp and put all the bits in a bag. I know you grabbed those joysticks but will just leave the unwanted bits n pieces should you or anyone have a use for parts etc.
Thanks again,
Rory.
