Suntory Tapper Sync issues
neoretro
1,121CR
Hi All
Got a Suntory Tapper and doesn’t sync with my Polo 3
Just wondering is there a list of monitors it will work with or is there an adapter I can get my hands on?
As would prefer to sit in the nice warm games room and play as opposed to the garage.
Dave
neoretro
1,121CR
Haven’t looked at the wiring just yet. Was hoping there was a list of monitors it was natively ok with.
I think most Hantarexs are composite aren’t they?
gunblade
9,132CR
no, most hanty have circuit for both vert and hor sync- its just most game board use comp sync and thats done on hor sync line of the chassis
neoretro
1,121CR
Ok cool. So the small issue here is I’m running it through a Jamma adapter which only has one sync pin.
Does this mean I’ll need to make a separate sync adapter to play the one board on the Jamma adapter?
neoretro
1,121CR
What pins are you getting for the syncs?
As this one reckons it outputs comp off of one pin?
gunblade
9,132CR
page 22 of the manual, unless i am looking at the wrong game?
https://www.arcade-museum.com/manuals-videogames/T/Tapper%20Parts%20And%20Operating%20Manual.pdf
original was fitted with wg probably k4900 or g07 according to the manual
pobtastic
477CR
They are completely different PCBs - I've lent mine to ... Smarty (I think!) maybe reach out to him if you need a photo of the PCB, I don't believe I ever took a photo of it.
Code:
Code:
smarty
Ready Player One
1,305CR
Code:
Code:
Yes it was me, Paul pm me your address and I'll ship it back! :)
If its the Sega board it will connect to regular System1 pinout as the Mikes Arcade diagram shows.
For whatever reason the Horizontal timing on these boards are at the edge of what most monitors can handle - god know why when they nailed it for all the other sys1 boards.
I tested mine on Arcade monitor, old RGB computer monitor, TV's and they all had a curl in the top part of the image or didn't sync nicely, adjusting horizontal phase to get a good picture worked, but other PCB's would then no longer sync to the monitors without adjustments.
I think there's an old thread on Klov talking about it. Image below, for clarity, its a three board stack.
gunblade
9,132CR
well you can try tying the vertical sync pin to the h/comp sync on the chassis signal connector with a 5k resistor or even try a short between the two, you may get lucky
