Super Cobra Corrupt GFX. No Sound
Purity
The Oracle
17 (100%)
2,999CR
Bought a Super Cobra PCB that was meant to be fully working, but of course wasn't. It was too much hassle to return to the seller, and I wanted the PCB so I decided to fix it.
First issue was corrupt graphics in-game and the board could also not run Phil Murrs test rom correctly
The test rom was failing at the screen ram test, so I checked the rams on the main board and found that a 2114 @ 3K had failed so replaced that and got all the GFX back
Next was the audio. To help with this I built Phil Murrs audio probe here which was very useful!
I was getting a low pitch, really loud noise, when I powered up the PCB. It
is quite horrendous! Adjusting the volume pot just seemed to make things
worse
I checked the z80 on the top board, and
the ram. I took the checksums on the roms which I need to check. I
popped out the AY chips, and the 8255 chips and the sound was still the
same.
Clearly the amp was working because I am getting some noise
Next I checked the outputs from the AY chips CH A, B & C - pins 3,4,38 with the audio probe and got nothing.
I checked over the z80 CPU which seemed ok.
Turned my attention to the 8255 chips. Popped them both out again and noticed a bent leg on one of them. Straightened the leg and the game sounds now returned when testing with the audio probe. I then tested the board properly on a cab and everything was working fine
Thanks to PhilMurr for his help
Now to do the multi-game board :)
Purity2018-07-29 10:30:39
