Super Cobra
jonhughes
1,156CR
Hi everyone,
I have an odd issue with a Stern Super Cobra PCB. Up is constantly on. I've discovered the problem but I'm not sure how to correct it. The schematics show A9 is up and is attach to a 0.1uf capacitor and a 220 ohm resistor.
Unfortunately, the 220 ohm resistor doesn't exist and the trace goes straight into a 0.1uf capacitor. I've changed the capacitor, to no avail. The resistance across the capacitor is about 10Mega ohms before and after I changed it. All other control inputs have a resistor attached to +5V to keep the signal high. When I place the logic probe on the trace in front of (and in series with) the 0.1uf capacitor the signal is driven above low and the up is turned off. Only problem is, once I press up on the pad the signal is driven low and stays low (so it's up on constant again. Place the logic probe on it and it goes away again. It's an odd one and one I hope someone has come across before.
The resistor should be at R32 and you can see where I changed the 0.1uf capacitor for a mylar one. When I touch the soldering eye at R32 the issue disappears as the circuit is driven above low but it never reaches high. Don't want to just connect it to a high signal, thought I'd ask first.
Thanks for any help.
jonhughes
1,156CR
Already sussed this, but thought it would be good to post as a reference to anyone else who may experience the same issue - repair log to hopefully follow.
jonhughes
1,156CR
favouredson said:
Why do you think that R32 is not there?
Surely, it is the one between R31 and R33!
The right-most of the row of 7.
The resistor would need two soldering eyes to connect it in at the required position - can only see the one to be honest.
I'm beginning to think the Stern Super Cobra PCBs are factory conversions of some kind. The Konami Super Cobra version requires no such mods.
favouredson
Super Star
1,260CR
You seem to be not looking at the resistors correctly. What you are looking at is just a PCB track.
R32 is on the PCB as marked below.
There are clearly eight resistors, farthest right is R31 and farthest left is R38, the one next to R31 is R32.
jonhughes
1,156CR
Ah yes,
I see that now. I wasn't counting the number of resistors and the trace in question (between R31 and R32) leads into C41 which then goes to the input for up. Have no clue where the actual R32 resistor trace goes to. It's not going to up, that I know.
I think it's to do with the Stern PCB being a factory conversion.
favouredson
Super Star
1,260CR
jonhughes said:
Ah yes,
I rummaged around earlier and found that I have a Stern SPB-1300 board and the track from A9 goes directly to pin13 of 1E. There is no 1K pull-up resistor, no 220ohm in-line resistor and it only touches c41.
The Konami boards have nine resistors instead of eight.
Even the Olympia board I have has all the caps and resistors in place.
