Super Hang On Screen Flicker
maroguy1
1CR
Hi, new to site looking for info for my super hang on sit down. Everything works except the backround of the screen flickers only while playing the game. When I run a ram rom test it comes up with ic20 ram is bad. I reseated all chips 3 times and touched up some of the solder joints on the board. Does anyone know which chip is ic20 and are there replacements available?? thx!!
cmonkey
1,659CR
Hi maroguy1. Welcome to UKVAC!
IC20 is one of the road ram memory chips. It's located at position 4B on the CPU (top) board of the board set. It's the lower left chip in the block of 4 outlined in the picture below. Replacement skinny 6116 2Kb rams are readily available from a variety of sources.
If you're going to remove this chip yourself then I'd recommend exercising extreme care as the board is 4-layer and it's very easy to lift and damage the traces on it too. It would be wise to snip the existing chip out (as you already know it's faulty) and then remove the remaining pins one by one.
Don't forget to post some pics of your Super Hang-On sit down machine when you've got it fixed!
cmonkey2014-01-26 20:59:32
maroguy1
1CR
Great Thanks for the advice that is exactly what I needed. The game is in pretty bad shape someone painted it black and covered all the decals on it so I really don't want to spend to much on it but it would be nice to get it working and play the crap out of it.
cmonkey
1,659CR
Hopefully you can get it working now. And then when you've finished "playing the crap out of it" and wish to sell it there'll be plenty of willing volunteers on here waiting to take it off your hands, black or not!
