Super Hang On
paulcan69
946CR
I have a super hang on upright which has no shaker/rumble motor working
And the dash lights (which light up the fake speedo/rev counter) are dim and pulsating
From what I read the rumble is to simulate the bike going faster
So it speeds up with your speed
I thought it was the motor
And a NOS one was supplied with the cab
So in test mode I went to output test (so motor was running)
And no voltage at the motor wires?
It has a solid state relay pcb
Pin 2 is from the game board which I’m getting between 1.25v and it pulses to 2.5v
Is that right?
Shouldn’t it be 0v and goes to +5v
Pcb fault?
If so can you test for that? (Some form of output device blown)
Any advice warmly welcome...
Anything else I test/check?
I think the Solid State Relay pcb also gets a voltage from the audio 2 pcb (Atari Ireland super hang on cab)
Could that be the issue?
I need to really start checking and testing everything
But just wondering if anyone knows any common fail points on this type of setup?
Uses the exact same Solid State Relay pcb as an upright outrun
I will start having a good check of all wires/voltages to check it a bit more (Continuity etc..)
If I get really stuck can someone with a working S.H.O get some voltage readings for me please?
Many thanks,
Paul
paulcan692019-04-23 16:27:31
Danscu
256CR
I have these exact issues with my Super Hang On upright, never able to sort it though. Mine is an Atari Ireland like yours Paul.
Hopefully a fix can be found through this thread!
Chopper79
668CR
The small orange board, is the SSR relay board. The big black component is the relay, and these can fail, but more ofter than not, they suffer with dry joints. Take out the pcb (Only 2 screws) and have a look underneath, and slightly move the relay and have a look for dry joints.
The motor is 12v I believe. Hook it up to a 12v bench supply, to check it. If there is not 12v getting to the motor, the problem, could be with the SSR, or the wiring.
I have a spare SSR board, and a motor.
The irish upright, also has an atari audio 2 pcb, which controls the volume/test mode, and audio.Chopper792019-04-23 18:45:47
robotech
823CR
The one i had was the same when i got it the shaker motor was disconnected ( i never knew they had one ) if you connected it up it would blow the fuse that ran the audio board aswell i bench tested the motor and it worked ok so i traced it back to that relay board but never worked out what was wrong with it
I lost interest after i couldent find a spare audio 2 board for it
Is it tied into the audio board in some way as the test swich is also on that board and they all seem to suffer from the same problems audio / shaker motor ?
paulcan69
946CR
Ok tonight I fixed it
I unscrewed the control panel and found 2x cut wires which traced back to the motor
Good start I thought
Then measuring voltage I found only 5v in the spare connector
Hmmm I thought
My flashing dash bulbs could be about 5v
So I unplugged the bulb connector and measured +15v far too much
So connected bulbs to 5v connector and they were solid no more flashing
So connected the +15v to the motor and it worked
It was a bit poor and somehow created distorted audio on the left channel only
So then connected to my "New Old Stock" motor and perfect
Dash lights solid and stable
No poor audio
And motor spinning fast
Touch!!!
Just need to swap motor over and refit
But for sure it’s fixed
So a fudged motor
And some previous dick plugging the connector in the wrong socket caused it all
(The connector for 5v and 15v to control panel are the same size, shape and colour)
Plus the wiring colours change at that point in the control panel anyway
Good ol’ Irish Atari wiring
Why do they do that?
Just use the same fu@king colours either side of the connector
Or use different shape molex connectors for each one so it cannot be swapped by accident
Anyway chuffed to say the least
It has rounded off screws in the control panel so swapping the motor will be a pain
Lucky I work in a car garage
We will sort that tomorrow
Thanks for listening
Hope it helps someone
paulcan692019-04-24 14:16:09
robotech
823CR
Proberbly the same issue with my old one aswell the bulbs used to flash on that too i thought they were supposed to
at least you have managed to sort it
paulcan69
946CR
Danscu hope your well
You’d do well to get that ssr pcb and motor from chopper in case
So when you do it you have spares
I would have bought them from him if i didn’t sort it tonight
I didn’t even know it had it
Most people with sho don’t know it does
Even better it’s not like outrun shaker/tapper
It’s a constant vibration to simulate motorbike vibrations
And speeds up as you go faster
Cool as fook
paulcan69
946CR
At danscu
Remember I met you
My mate had your poker machine and golden tee
Your sega yellow start button is on my cab and working in full glory
It lives on...
Plus I used your spare dash bit as mine was in a worse state
Again thanks for that
Going to get my mate to paint the cab white again
And Grant to do monitor chassis
New stickers and done
Lucky the board is a non suicide version
So no need to replace cpu and roms
robotech
823CR
Its a great game i miss mine tbh but i really wanted a pinball machine at the time
and the only way i could afford it and have the space was to sell two cabs my sho and my neo geo
Danscu
256CR
Cool as fook
Hi Paul, great that you posted this thread and got it sorted, and I have emailed Simon as you advised. This must be such a common problem by the looks of it!
Danscu
256CR
paulcan69 said:
At danscu
Remember I met you
It lives on...
Remember well mate and glad the parts came in useful! Hope all is good your end!
