Hi just got this super pac man pcb today with a cab but when plugged up it just displays this screen.. any ideas?
thanks
[DIVstegrey2019-03-22 13:06:38
thanks
stegrey said:Does anyone know what sort of rom burner i could use to check this? Would a gq4x one work? ... i have never used a rom burner before so have no idea .. would like to learn though cheers
stegrey said:Cheers for the reply.. reason i mentioned that burner is because ive seen it on loads of sites and mentioned alot.. im was worried as ive heard people mention adapters needed for certain roms?.. what are they like to use? Is it easy?
Thanks![]()
Chopper79 said:stegrey said:Cheers for the reply.. reason i mentioned that burner is because ive seen it on loads of sites and mentioned alot.. im was worried as ive heard people mention adapters needed for certain roms?.. what are they like to use? Is it easy?
Thanks![]()
I can recommend it. I initially did some research on burners, but decided on this one, as it works with older eproms. I've burnt loads of roms on this, and never needed an adaptor. I had never used a burner before this, and found very easy to use, with a easy interface. It's usb as well.
