System 22 cpu board/s
paulcan69
945CR
Please can someone fix these or look into how these are fixed, please?
I now have 3 boardsets all with cpu board faults - the same damn fault.
My bet is the fan gives up and something on these cpu board gives up which stops the data getting to the rom/video boards.
I have 2 cases with dead mains fans.
All 3 boot but have no 3d, all fail the same tests in video and if they were pc's you'd say "I bet it's the video card"
Well these have a giant video board and the fault is always the cpu board.
WANTED spare Namco System 22 cpu boards.
I have running:-
1x Ridge Racer 1
2x Rave Racer
Then all with the same fault on the cpu boards:-
Ridge Racer 2
Ace Driver
Ridge Racer 1
But as soon as I swap in a known working cpu board they run fine!!!
Please can someone discover this common fault, I could probably even change the component myself but have no idea how to fault find these.
I have some surface mount gear now.
Unlike Model 2 stuff which goes crazy and displays all sorts of mad faults, these do the exact same thing, all text present, games boots and starts if coined up, has sound etc... just no background or 3d at all.
These boards are Playstation 1's on steroids, are there common PSX faults which happen in the cpu section, I know these are way more complex just someone out there must know something??
These are getting harder to find working stacks in the future we will have to repair them.
I'm gonna run into trouble keeping my cabs going as I now have no cpu boards left!
+ I'd like these other boards up and running to play sometimes. (Without having to swap loads of stuff over which takes about 20 minutes)
Many thanks for any ideas or advice on where to start + who to speak to...?
Paul.
paulcan69
945CR
Yeah?
Please if you can find it bud?
The more of these I have the better.
Then I can help tb2000 out with the roms.
So yes please dude!!
paulcan69
945CR
Well tried my untested Ridge Racer 2 board tonight and guess what, no track, no 3d only text hmmmmm wonder where I've seen that fault before ....oh only maybe 12 times in this last god damn week!
Ok let's see if it's the cpu board at fault....again....(like all the others)
Oh what a suprise!
Same fault as my other 2 non running stacks, swap a cpu board in and I'm now playing RR2.
Anyone would think it was a common fault....
Trouble is you can never get a working cpu board without buying yet another full stack in a metal case, I have 3 in my front room and all the cabs that take them are full up!!
I want yours Alpha 1 but I'm running out of room!
How much to rid you of it? PM if you would good Sir?
Then I can sort out tb2000 the RR1 rom set he needs and have a spare RR1 set for my board.
Ta
paulcan692011-07-28 22:45:30
lezardvert
9CR
Hello,
I'm Lezardvert and I'm french passioned by Namco arcade cabinet.
Recently I have bought a twin ridge racer 2 cabinet (system 22) and i have the same symptoms you have. Exactly the same for the two boards set.
Did you find some information to repair them?
at the starting , ridge racer 2 title flashes and i have only text and sounds , the game seems works fine but no pictures no 3D!!!!
I contacted Namco service by mail , but no response for the moment , probably there is no support now for these kind of cabinet.
I refurbished completely the cabinet , I thought the electronics aspects will be details but no...
Best Regards.
Sorry for my english..;-)
Lezard vert.(green lizard)
paulcan69
945CR
brent/namco uk say they can still test + repair these, but 60 per hour i would still like to try to repair myself, i have 4 faulty boards so it will be cheaper for me to buy working boardsets
lezardvert
9CR
Hi,
I'm electronic engineer, but without schematics it is very hard to understand.
I'm sure Namco team has technical data base with symptoms described and can probably repair quickly but the cost could be expensive regarding the cost of the cabinet.
The interesting could be to obtain informations from a person with the same issue.
(in add the most important point could be if the bad component is a namco custom part or programmable , very difficult to solve for us).
I'm exploring the point rom/ram board.
it seems when the RAM is bad we can see that in the cpu test ...test 6 is bad with addresses corrupted value.
The problem for me is to check ROM, because the PCB is multilayers and it is very difficult to remove parts without damage. These ROM parts could be replaced but difficulty and cost are important.
I hope, a person(who has this problem) will post information on this forum....
Rgs.
Lezard vert.
trm
2,877CR
Bonjour serpent rouge ;)
Welcome to ukvac!
There are very few people outside of Namco who work on these it seems and it doesn't look as though any schematics have leaked. I replied to another thread of Paul's with some ideas of where I'd start to investigate.
I've not really thought about it since but would be interested if you've got any ideas?
http://www.ukvac.com/forum/forum_posts.asp?TID=329500&title=reflow-how-to-shall-i
cheers
tim
argonlefou
7CR
Hello paulcan69,
It may not be a usefull help but as I had some issues with Sytem Super 22 PCB :
- M.A.M.E Driver comments for this system. Huge amount of information ( cards, ICs, layout). Unfortunately most of them detail SytemSuper22 and not System 22 :(
But with this, you can maybe try to alter some of the rom dump in the MAME bios files and maybe you'll be able to locate witch chip is faulty.
- This seller on ebay may have some PCBs to sell (he had some not sold recently, don't remember if it was ram/CPU/video though) . He's reliable (I bought him 5-6 Sytem super 22 PCBs recently). You can message him for what he still have, and he can decrease shipping costs (if possible) if you are not in the U.S
As for repairing you faulty PCBs....I can just say "good luck" ;)
argonlefou2011-08-31 22:55:16
ridge-racer
6CR
Hi Paul,
Did you ever find out what was causing the CPU board to be faulty?
I have a ridge racer 2 with the same problem. I cant source any info for this.
Mike
tb2000
3,578CR
It's a common problem on S22 pcbs, i've got a number of them all with similar problems. On one pcb someone had replaced a load of ram at some point in it's life which must've fixed something, but not sure what!
ridge-racer
6CR
Hi,
Thanks for the information. You wouldn't happen to have a working board set or a working CPU board for sale would you?
Regards
