T-moulding substitute?
Mr20to5
1,366CR
My money would be that this would stick fine to a perfectly smooth, clean, flat, straight surface fine.
Anything else and it would come off, rough wood, tight corners, etc.
But I guess you would never know until you try...
Ronnie Dent
1,206CR
That was my thoughts too
Ronnie Dent
1,206CR
Elektronix said:
Rather than using flat chrome stick on stuff like on that link, why not just use chrome t-moulding like the ones here?
https://www.arcadeworlduk.com/categories/t-molding/3-4-t-molding-0-75in-19mm.html?sort=bestselling&page=1
My jamma cab had that ribbed chrome stuff too, looked awful, was all chipped & dull looking. Replaced it with the black leather effect one, goes nice with the wood grain
Yeah mine in not wood grain it's like a gray wood, also it's 20mm
Thanks Ronnie
Elektronix
11CR
Mine's 20mm too, 19mm t-moulding that's like half a mm either side, you can't notice it at all (I just used a black sharpie marker to go over it if some sections were a tiny bit wider & noticeable.)
Have you done t-molding before? this vid helped me when I did mine coz I didn't know the little tips like using a rubber mallet, cutting a section of the barb off on corners etc
T-molding starts around 36 mins in.
Elektronix2022-07-05 22:16:43
Ronnie Dent
1,206CR
Thanks, yes I have done a couple of jobs with it, I find some of the newer stuff is more plastic than rubber so harder to get flat.
I could have painted the old stuff black but it has shrunk in places and no longer sits in the bends!
Thanks Ronnie
2,265CR
I've got some of this stuff to do my Buggy Boy as it was the only way to get flat chrome. Not a chance will it stick by itself. I'm going to have to remove the foam tape on the back and hot glue it all the way along to have any chance of it working.
Ronnie Dent
1,206CR
I have bought some anyway as it's cheap as chips! I will try a bit on a scrap piece of chipboard, as said probably won't work I'll use hot melt as muddy suggests
Ronnie
