T2 guns not working
Mr Bond
76CR
Hi all. Wondering if anyone can help here. My T2 machine is really starting to piss me off.
The guns fire but don’t move on the screen, I can’t calibrate them as there’s no reponce at all.
The leds on the guns & the flash lamps don’t flash, and the recoils don’t work when testing through diagnostic menu, it’s as though the gun board isn’t plugged in. The 20v led lights up on the gun board, but the 5v one doesn’t, Not sure if its meant to light, flash or what? There is 5v at the board though, but the led isn’t lit.
Can’t find anything wrong with the gun board, two chips on there have been replaced and all other components checked, can’t find anything.
Opened the guns up today and apart from a bad solder joint on one of the gun pots I can’t see any fault with the wiring anywhere, or anywhere on the cab itself. Board runs fine, sound ok, monitor ok.
I’m baffled.... I must have missed something here, anyone had this issue?
Thanks chaps.
Mr Bond2019-03-26 19:46:07
channel27
1,377CR
Similar problem here, other than my 20v ac transformer is knackered (measures 0v and the LED isn’t lit, obviously)
From my Googling, the main culprit is normally those 2 chips. I, like you, have replaced them already.
Is the bridge rectifier OK?
Mr Bond
76CR
Just watched Todd Tuckys T2 arcade video and paused it where he pulls the board out and both the 20v and 5v LEDs are lit on his... wondering if it’s a main board fault?
channel27
1,377CR
Yes, the square thing on the gun / coil board :)
My 5v led is on, if I remember correctly.
I don’t think that the 5v feed comes through the main board though. It probably comes straight from the PSU.
With the game off, try measuring continuity from the the header on the gun board back to the 5v output on the PSU.
Mr Bond
76CR
Ok I’ll try that. Gotta be that 5v line somewhere as it’s just not lighting up.
Cheers pal. Sounds like youve got the 20v problem then. Do your guns track on screen? Thought the 20v was for the flipper coils?
Ace`
PlanB contributor #1
40 (100%)
4,040CR
The 5v led lit up my end I believe (my memory sucks). Are you getting 5v at
the pots in the guns? that's how it reads the movement of the
crosshair.
channel27
1,377CR
I guess the fuses on the gun board are ok?
My cab has no gun tracking (but I can fire - Perfect if you want to shoot top left...!)
No recoil or flashing lights either, but the LEDs on the guns are on.
Mr Bond
76CR
crosshair.
I’ll test again tomorrow mate.......
Swapped the two chips. The dip20 although listed as “new” had bloody corrosion on the legs! Never been new. Cleaned it up but for all i know it could be toast. Emailed em back, I’ll see if I can get a replacement. Mr Bond2019-03-26 21:06:08
Mr Bond
76CR
Yeah all fuses are ok. I’ll do some testing tomorrow.
Mr Bond
76CR
Working!!
I ran two wires out from the power supply straight to the gun board 5v input and it works. Must be a break someonwre between the gun board and the main board in the wiring although I checked continuity and it seemed ok.
Ace`
40 (100%)
4,040CR
Nice one, so everything is working now?
As for the credit issue that could be the credit board or game board issue. Does the service switch work?
vids
143CR
Hi nope service switch does nothing as well ta
Ace`
40 (100%)
4,040CR
Sounds like a board fault, you can confirm by trying it on another jamma cab / supergun. You can set it on free play with the dips if you aren't bothered about having to coin it up.
