T2 Video Sound issues
Big Phil
Captain Phil
538CR
I've just picked up a T2 video arcade machine and there is no sound.
Looking at the sound board, there have been a few leg repairs to chips U12, U13 and U14.
I noticed another snapped leg on U12 which I've repaired myself.
In the diagnostics, when I do a sound board test, it report everything as ok. Especially these chips!
When there is supposed to be sound, I just get static.
Any ideas?
Big Phil2013-08-15 19:38:56
stevebm1
39 (100%)
1,269CR
right here's how to test it's working,run the ribbon cable straight from the main pcb to the soundboard,bypassing the gun board,then go into the test mode and try the sounds,if you get no sounds,try turning the ribbon cable around at the sound board end only,and re test,if that does not work your sound board is faulty,also check the power cable is providing power from the main board,it could be a dodgy connection on your loom
hope that helps
stevebm1
39 (100%)
1,269CR
hmm,seems the sound board is knackered then,I will have a look for you in my loft,as I got a big box of t2 spares with my large cab when I got it.
steve
