Table top repair
MRA230467
1CR
Hello,
I have a arcade table top games console that now refuses to start - the screen is powered up as a green LED verifies but the games do no load - can anyone advise? Thank you,
MRA230467
1CR
Sorry about that - pi
tures would help I guess !! Here we go.
sherr03
103CR
Your Dip settings look ok for a LCD monitor. You could try flipping dip 4 to on and see if the settings page appears. Also do you have the monitor set to the correct input?
r-type
633CR
Can you plug another source into the monitor to rule that out? Otherwise that appears to be a 60 in 1 board in there. They are cheap to replace.
Have you got a multimeter?
TheDaddy
14 (93%)
7,230CR
Yeh agree - test monitor with another source (Pc ect) or if you have a jamma board throw that in. Also check the voltages to the board as they may be low.
Dave.
MRA230467
1CR
Thanks guys I will test the screen now - really appreciate your help with this. If it is the board, where can I get one from?
MRA230467
1CR
Oh great - i'll look on Ebay - do I need to search for a particular model code or just a 60-1 board? Also I've tested the screen from an external laptop and it works fine.
sherr03
103CR
Did you try and put the dip switch on position 4 to on? This will put the board into setup mode. The first screen should show a calibration pattern on the monitor. Might be worth trying just to make certain the board in knackered.
MRA230467
1CR
No even with dip switch 4 either on or off no LED's flash ? I check the screen using a laptop and the screen worked fine. Seems to point to a faulty board would you say?
MRA230467
1CR
Ok, should I order a power supply as well just in case do you think ? I have ordered another board from Ebay for £27
Are the power supplies pretty much the same standard config?
