Taito Rastan pcb - OBJECT RAM ERROR
My Taito Rastan board has started showing garbled graphics, vertical white bars and missing character sprites. (Typically after finally getting monitor convergence/purity spot on too in the cab it was going in ;!
A test mode shows the error "OBJECT RAM ERROR"
I've tried re-seating all chips.
Am I right in thinking the Object ram chips are IC2 to IC5?
Would the next step be to socket those and try new 2018 chips in?
Don't think they are suitable to piggy back to test can then?
Anyone familiar with this board?
Many thanks.
TheDaddy
14 (93%)
7,230CR
Not familiar with the board but piggy backing will be ok to do. Does not always work though.
Also check the voltages are good on the 5v
Dave.
TheDaddy2021-09-08 14:37:13
Thanks, will double check voltage level. The chips on the board are MCM2018N35 , looking around I can find MCM2018A35 but not N35. Anyone know if they are compatible?
Great suggestion on the 5v Dave... checked and it had dipped to 4.81v at the board.. enough for the MVS one slot that was in there previously to run ok but not enough for the Taito Rastan. Upped it to 5.01v and the object ram error and graphic issues went away. Glad checked before ordered new 2018 ram chips, but looking over the schematics was good practice anyway.
Thanks again.AnOldCabinet2021-09-09 21:09:58
