Hi guys!
I need help with my SCI from Taito. First of all, it is a European license build of the company Negro in Italy, (unfortunately, the wiring etc. is somewhat different than in the US model).
I have the problem that the shaker motor does not work. I have then already searched for the problem and the problem already narrowed down. The supply line (red and white) to the transformer that supplies the motor with 24 volts has been cut off in the area of the main connector of the PCB. I have no idea where the cables were connected, nor how many volts go into the transformer.
On the motor itself, the yellow cable (drive) is also not connected, and a plug on the motor (black, red) is also not plugged in (is it needed at all?).
If someone has the same model, it would be great if he could send me photos. Or could measure how many volts are going into the motor transformer.
A shematic of the Taito/Negro SCI would also be enough for me. Unfortunately, one finds in the net only the shematics of the US version.
Thanks a lot and greetings
Daniel
Danschki2021-04-13 06:33:51
Daniel
