Taito space invader
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Hi all, just picked up the space invader from gumtree. It is all complete but not working.
Checked all the fuses before switch on and they all seemed ok. Powered up and the first fuse onthr power brick keeps blowing, the 3 amp one. Monitor neck glows and the 2 florecent tubes glow. On power off you get a white line across the screen going to a white dot.
Don't have anymore time to look at it to tonight as off to Holland at 3.30 in the morning for work.
Any ideas why the 3 amp fuse keeps blowing? Have not had chance to check voltages tonight.
Any help would be good so I can restart on my return from holland.
Cheers,
Steve Steve2013-07-09 21:49:17
mathj
499CR
hi
sounds like its a psu issue to me
no doubt someone will have more info but from your description it sounds like everything else is checking out visually anyway
good luck
math
mathj
499CR
I had a space invaders tabletop do the same thing
turned out to be the power supply board
as Phil says, try disconnecting everything the psu supplies and try it again
if the fuse still blows it is more than likely the psu
math
Equites
Chief Sheesher®
35 (100%)
3,329CR
Check the bridge rectifiers on your PSU board;
Once I had rebuilt it;
PSU completely rebuilt and ready for another 30 years of service;
Equites2013-07-10 00:53:01
bonehead
50 (100%)
1,729CR
Ok I will try that. Anyone in the uk sell the ar1 psu rebuild kits? I guess I could source all the parts individually but would be cheaper as a kit.
Cheers,
Steve
bonehead
50 (100%)
1,729CR
Update.
Changed the little blue caps and a couple of resistors that were showing a reading of 0. Replaced the resistors but they still read 0. Machine powers up now and does not keep blowing the fuse.
Re- seated the chips on the game pcb. Checked the voltages on the board connectors and they seem to be ok. +5 +12 -5.
The game still does not boot. Monitor glows and still shows the white line and dot on power off.
The pcb is the L shape, on the bigger board in the scketed part i have no chips in ABCD but do have them in EFGH, is this right?
The cab seems untouched inside and looks like no parts have ever been changed or repaired.
Where do i go from here?
Maybe i need the power board checked and the pcb? just to make sure they are actualy working.
Steve
Steve2013-07-11 22:06:58
forcefulfil
EDOT King
17 (100%)
1,675CR
if the voltages on the pcb are all good,i.e. what there supposed to be then it sounds like you have a pcb fault.
i wouldnt recommend trying to have a go at repairing this,otherwise most pcb repair guys wont touch it after
there are folk who repair these.
P-man is one (if he aint too busi)
and the next specialist is redacra off e-bay aka neil breeze
they will infact repair/check both if needed
bonehead
50 (100%)
1,729CR
Thanks for the advice. I was going to see if there is anything I could try before sending off for repair?
I will check voltages again over the weekend and report back.
Steve
bonehead
50 (100%)
1,729CR
Right hat checked voltages on edge connector and all are present and correct.
Still no life from the pcb. I am getting 4.95v on the rom chips on the bigger board.
The smaller board has wires soldered direct to the board and then to a fingerboard which goes into the other edge connector. The 12v and 5v are not wired to the fingerboard it pcb. Is this correct as the edge connector has the voltages present. As I said in my first post the machine seems original and not hacked. The previous owner had it for 10 years and one day it just stopped.
Any ideas or does it sound like the pcb is faulty?
Cheers,
Steve
aaablettt
10CR
Hi Steve,
Check/resolder the plugs A, B & F at PSU board. Some times they can break contact at the solder side. Then, if thats OK go to the pcbs, remove them both and fill the sink at home with warm soapy water, grab a nylon nail brush and an old tooth brush and scrub them, rinse and dry. 35 years of nicotine tar & gunk can be hard to move! I dried mine over the hydronic radiator for 24 hrs hanging by a wire about 24 inches above the top. Once thats all done, make sure your board connectors are clean. Use some contact cleaner like crc or rp7 but scrub them too. Recheck your voltages: 5v, 12v & -5v at the pcb.
I hope you have isolated the video first by either running a signal lead to a known working video or running an rca lead out of say a dvd player to the cab video?
Let me know what you see.
Jimmy in Oz.
RaveN
1,325CR
Hi Steve,
I don't suppose you can take a pic of the daughterboard? I'm wondering if it's a non-taito aftermarket one like a Zenitone-Microsec (although that shouldn't need a fingerboard as it's a direct swap). An original daughterboard does require 5v and 12v.
Here's a pic of the insides of mine, does it look the same?
Also, do you have a logic probe?
