Taito type x
mozie
20 (100%)
530CR
Having a mare of a time with these pc based systems lately and I thought jamma boards were unreliable?! This is a nos boxed type x, just popped it in the vewlix today and it's powering up, fans spinning, lights on motherboard etc but no video output at all, so far I've tried it on another old crt I had lying around had a poke around inside and reseated gpu, ram etc and no luck, any advice on where to go next?
Velyks
100CR
Does it have a HDD in?
Are you plugging it into the right port? On TTX1 and TTX1+ the VGA port is 15khz and the DVI port is 31khz
mozie
20 (100%)
530CR
Yeah came with a game I have it connected through the top dvi port using the dvi to vga adapter tried bottom one too.. Not getting anything
FanDabbyDozy
22 (100%)
170CR
They guy is hit and miss with things, the Type-X did look in great shape.
Just dont think he tests everything,
Bought a 256 from him and got a different one to what was shown (was not a multiple item listing either), the one I got was missing the rear mounting, as must have been torn off at some point.
On the up side you never pay duty with him
mozie
20 (100%)
530CR
True I got a 246 and a few other bits from him and it was working fine, can't figure this out surely I should be getting a bios screen or something at the least
mozie
20 (100%)
530CR
Yeah tried removing it and popping it back in, when I removed it I turned it on to see did I get a beep or anything but got nothing at all, just same 2 red lights on motherboard and fans spinning :(
FanDabbyDozy
22 (100%)
170CR
Not sure if they have a built in speaker, might be able to add one to the board to hear any fault codes as just a pc motherboard?
Have you other ram to try?
Just sounds like not posting if no output at all.
mozie
20 (100%)
530CR
Tanks for the response guys it's model 022A, definetly seems like it's not posting because I can't hear any activity on the hdd, don't have any compatible memory here at the moment, will try find some compatible stuff
ZeroSum
34 (100%)
942CR
From my experience if the machine powers on but displays no picture try changing the ram first.
and then try another GFX Card if that doesn't work.
ZeroSum2021-03-03 20:16:59
gunblade
9,136CR
check the cpu seating, it may look like cpu heatsink has not moved but they do have a habit of the cpu becoming slightly dislodged during shipping
