Tech advice : Gauntlet
5,324CR
[uk-vac] Tech advice : Gauntlet
I have an old Atari Gauntlet (the big 4 player beastie) which has been
working just fine for a few years. While I was off on holiday, some bright
spark decided to move it - rather than using a trolley, they 'walked' it
across the room.
Now, when the power switch is flicked - it immediately blows a fuse (I
can't remember which one off the top of my head).
Where would be the best place to start looking?
Dave
DATA Imported from archives: originally posted by David Cowan (cowan.david@gmail.com)
MikeDX
22CR
Re: [uk-vac] Tech advice : Gauntlet
I'd check the power cable to make sure it hasnt been trapped/shredded
for a start.
> across the room.
> Thanks
> Dave
5,324CR
In message <ed4df47b0511030739g222d97bev@mail.gmail.com>, Mike Green
<mikedx@gmail.com> writes
>for a start.
Then check for loose metal bits (including coins) that have dropped
where they shouldn't be.
Clive Mitchell
http:/www.bigclive.com
DATA Imported from archives: originally posted by Clive Mitchell (bigclive1@ntlworld.com)
5,324CR
Right... the power cable seems to be untouched (no signs that its been
yanked or run over), and there are no loose bits inside the cab.
The fuse on the PSU that keeps popping is marked as F3 (2nd one down if
you've got your head inside the cab from the rear and looking down).
The cab powers up (the coin lights and marquee), and the monitor whines as
it heats up.
> >for a start.
> Clive Mitchell
Ordyne
1,282CR
RE: [uk-vac] Tech advice : Gauntlet
Sounds like the bridge rectifier on the powerbrick, remove the powerbrick
and test the bridge rectifier with the diode test on you meter.
Best regards,
Craig
Craig Walker . Giz10p Games . 424 Carlton Rd . Carlton . Barnsley
m: 07966 311840 e: craig@giz10p.co.uk w: http://www.giz10p.co.uk
5,324CR
Looks like it was indeed the rectifier... it appears to be shorting. I've
ordered a new one from CPC.
Now - on a related note - anyone got a CPC reference number for a 20A 32v
fuse? (its the one that kept blowing)
Dave
> Best regards,
> Craig
4,058CR
You probably want B&Q for one of them. They sell 'em in either
flathead or round varieties in various lengths.
:eek:)
Fixing cabs the Bazfish way - LOL!
On 8 Nov 2005, at 18:25, Craig Walker wrote:
> I doubt they do that value..
> Best regards,
> Craig
5,324CR
B&Q do them, but CPC don't? What's the world coming to? lol
> :eek:)
4,058CR
PS: I was referring to nails!!
>> :eek:)
5,324CR
*blush* oops... guess who feels like a right tit now! I was getting my coat
to head up to B&Q at lunchtime
I'll get you for that Guddler... you'd better start sleeping with one eye
open!!! ;)
