Tech: Asteroids Cocktail
the-hat
71CR
[ukvac] Tech: Asteroids Cocktail
Hi People.
Not sure if this has been asked before but :::
My asteroids Cocktail just arrived from California, and I just wondered:
I know obvoiusly that this runs on 120v and it is currently running ifne
with a external transformer i have, but i wish to convert it internally, and
wish to know if I can just change the jumper cablesin the psu . It
currently has about 4 sets, and only 1 set is in use. Is there a different
one to determine UK power to US, or should i just ignore all this and fit
one of my 240/120 tranformers inside (seems a bit of a waste if i dont need
one!).
All help greatly appreciated.......
Kev.
PS. TOM - if you are reading, i will be in touch probly friday re: testing
my board in your cab !!. is this good?
5,324CR
Re: [ukvac] Tech: Asteroids Cocktail
hi kev,
here is the section i copied out of my manual for you regarding voltage
selection:
page 3 of asteroids cocktail manual:
1. voltage selection
before plugging in your game,
make sure that the voltage selection plug on the power supply is correct for
your location's line voltage.
check the wire color on the plug and see if it is correct per the following
list.
LINE VOLTAGE RANGE VOLTAGE SELECTION PLUG COLOR
90 -110 VAC (100) VIOLET
105-135 VAC (120) YELLOW
200-240 (220) BLUE
220-260 VAC (240) BROWN
so go for the brown dude!!
hope this helps
STICKY
DATA Imported from archives: originally posted by Richard Monro (stickyy2k@btinternet.com)
