TECH: Asteroids
marog_uk
33CR
[ukvac] TECH: Asteroids
I've got an Atari Asteroids board that produces a display image the size of
a postage stamp!!! I have tried adjusting the X & Y pots but this makes no
difference. It's not the 19" monitor either as is works fine with an
Asteriods Delux board.
The image produced is about 1/2" by 1" and appears on the left, center of
the display. You can just make out the asteroids, ships etc. in game mode
and the criss-cross pattern in test mode. I connected up a scope to try and
amplify the small signal being generated, but couldn't get a stable image.
There is no sound either in game play mode - but I do get bleeps when I push
buttons in test mode.
I looked at a couple of 'Asteroids' trouble shooting websites - but nothing
like this is ever mentioned. I suspect it is something to do with the
Vector generator / amps - but don't really know where to start looking.
Anyone seen this problem before? Can anyone give me some pointers to which
components to test/replace?
Cheers,
Steve
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
retroshaun
54CR
Re: [ukvac] TECH: Asteroids
And on a similar subject I STILL have my problem where the image
displayed is correct across the X but 1 "pixel" (one vector) thin in the
Y, across the center of the screen.
I was told the board was working OK after it being repaired so could it
be the monitor?
Can anyone fix this for me?
Shaun
> size of
> makes no
> of
> mode
> try and
> image.
> I push
> nothing
> looking.
> which
> Cheers,
> Steve
> Yahoo! Groups Sponsor
ADVERTISEMENT
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
5,273CR
RE: [ukvac] TECH: Asteroids
A quick check to verify the board is to use a voltmeter on the AC voltage
range, put one probe on GND on the board and the other on the X & Y test
points in turn ... if you see 0 volts on the Y then the board is probably
dead - it should be about 3/4 of the reading you get on the X axis if both
size pots are adjusted to the same position.
If Y (and hence the board) is faulty I can help, otherwise you need a
monitor man!
Steve
DATA Imported from archives: originally posted by Steve Coule (steve@coule.freeserve.co.uk)
5,273CR
sounds like a problem with one of your chasis transistors on the monitor
either one has died or a connection is not being made
if you dont know anything about monitors then leave it to some one else to
fix that does
as there is quite a bit of high voltage in their even when you have turned
the thing off
where are you located by the way
Mark
DATA Imported from archives: originally posted by markgwilliams (markgwilliams@ntlworld.com)
retroshaun
54CR
I know *nothing* about moinitors (and not a huge amount about boards
either by the way!) so would definately need assistance. As the board
was already repaired and verified as working, I suspect its the monitor.
I am actually in Surrey but the machine (presently) is in the North East
(Durham area).
Can anyone offer help with this? Of course all costs will be covered,
goes withot saying.
Shaun
> monitor
> else to
> fix that does
> turned
> the thing off
> Mark
P-Man
International man of mystery
1,272CR
check the +15v and -15v regulators in the AVG section...
Andy
of
no
and
push
nothing
which
> Cheers,
> Steve
