tech: bombjack ram 5
5,324CR
[ukvac] Re: tech: bombjack ram 5
Not sure which is RAM 5 without looking at the schematics, but you
could try this method:
Leave the board running for four or five minutes, then place your
finger on top of each RAM chip in turn. The one that's fecking hot and
burns your finger is the faulty one ;)
If that doesn't work I'll dig out the schematic...
Dave
DATA Imported from archives: originally posted by David Smethurst (david@smethurst75.fsnet.co.uk)
Re: [ukvac] Re: tech: bombjack ram 5
Hi
I have now figured which ram it is, but its not the
ram chip that is faulty.
Ram 5 is in the middle of the top board, but gets
written to from the bottom board, which is where the
fault is.
I thought that ram 5 was on the bottom board because I
knew the top board worked fine.
Odly ram 5 holds the text layer, which if it is faulty
you won't see the test screen!. In this case the
screen is very garbled so I can see enough to
establish this.
I have tried the hot chip thing before, but I didn't
know to leave the board on for 5 mins so it never
really worked for me, I will try that next time,
thanks.
Rob
--- David Smethurst <david@smethurst75.fsnet.co.uk>
> schematics, but you
> then place your
> Dave
