TECH: Elan C41 Eprom Programmer
marog_uk
33CR
[ukvac] TECH: Elan C41 Eprom Programmer
A while ago I bought an Elan C41 EPROM programmer - it works just fine
reading and writing EPROMS. But I am having difficulty getting it to upload
EPROM images to my PC, so that I can run ROMIDENT.
I've connected it using a standard RS232 cable, and can communicated with it
using standard win98 HyperTerminal. I can use this to execute remote
commands, and using the text file transfer command, download images into the
C41. When programmed onto an EPROMs these download files work fine.
My problem is when I upload an EPROM image to my PC using the Hyperterminal
text file transfer, some bytes are lost (about 20%) and I end up with a file
of garbage. The terminal is set to 8 bits, and settings match those of the
programmer. Any ideas how I can get around this problem?
Ideally I would like some dedicated software that could upload, download and
remotely control at the touch of a button.....anyone on the list know of
such software?
Cheers,
Steve
_________________________________________________________________
Send and receive Hotmail on your mobile device: http://mobile.msn.com
4,058CR
RE: [ukvac] TECH: Elan C41 Eprom Programmer
Steve, I have an Elan C41 sat in front of me and when I bought it I had
exactly the same problem. The reason you're getting garbage (I suspect,
though it sounds like you're far from thick on the subject) is that
things are not going across as binary.
Sounds like you already know how to do this, but hold down reset until
it beeps twice at you and make sure you have selected the output format
"binary no header". In hyperterminal ensure you use binary transfer mode
and transfer the file.
When it's gone over you will need to strip the last three bytes from the
file before romident will be able to ID it (0x0D, 0x0A, 0x1A - or
CR/LF/EOF in plain old english). For this you will need some good hex
editing software that will allow you to delete bytes. I use an old
version of CodeWright that came with Compuset many moons ago.
I did set out to write a program that would communicate with the C41
direct and remote conrtrol it, but this was simple in theory as the
C41's manual tells you exactly how to profram it, it proved rather
awkward, and then pointless when someone gave me some software for a S4.
The S4 software will transfer files backwards and forwards, but no more.
You will still need to strip the surplus byte pattern from the end of
the file.
I also set out to write a little program to do this to all the ".bin"
files in a directory. This WILL get finished soon (funnily enough, only
thought of it today when I archived all my source). I'll let you have a
copy when it's done, but as with anything it's in the pile of things to
do somewhere! At least that should only take an evening. A rough and
ready jobbie would take about half an hour in C/C++, a decent version
will take an evening.
I'll also forward to you (off-list) the S4 software, if you want it,
please LMK.
Cheers for now,
Guddler.
PS: Just fired mine up to check this and it's bust with "Fail VPP power
check" - what f**k is it with me this week. First the scope, now the
burner - this is getting expensive :O(
Martin White
http://www.guddler.com
Arcade search site with PCB info too...
4,058CR
Further to that last one - do you have an RS232 cable or a null modem
cable??
I now remember having real problems farting around with it when I first
got it, I had plenty of 'correct' looking cables, but in the end I
relented and bought a good null modem cable, and bingo it started
working.
I think I was having the same problem as you in so much as it worked
fine to the programmer, but useless to the PC.....
Guddler.
Martin White
nelper
3CR
I have a C41 programmer without a manual.
I've managed to copy chips ok but would like to know the instruction set to used via a serial connection.
Also which terminal emulation to use...vt100?
Or get a copy of the manual
Many thanks
JD
milbourne
3CR
Hello
I have recently acquired an ELAN C41 and have the same error message when trying to program anything: 'Fail Vpp Power'.
Did you ever find out the cause and manage to repair this fault?
Kind regards
Ross
