tech help home security project
gridrunner
Ex-lurker!
206CR
Hi Guys,
I have a small radio alarm system that I used to protect the garage and back gate. This connects to a receiver and small piezo sounder inside the house. I also have a Panasonic PTZ IP camera that I use for motion detection and this has a number of switched inputs that can also be used to trigger its own alerting (it can send me SMS alerts through an e-mail gateway). What I wanted to do was to hook the sounder up one of these inputs and use a small micro relay to replace the piezo sounder. The reasoning went that when the alarm sounded the relay would close and trigger the camera. OK, so that sounds reasonable.
The only problem is the circuit doesn't drive the sounder that way. I was expecting to see a voltage applied and a modest current on activation. Instead, a voltage of 4.5 - 5V is present all the time. The very modest current draw on the relay (around 50 - 60 mA) means that the relay activates as soon as it is attached to the circuit. This is because the nominal current measured when the speaker isn't sounding exceeds the activation range of the relay. It measures 150 - 200 mA when the alarm is inactive.
What drives the speaker instead is a big increase in current. This rises to just under 3A when the alarm is sounding.
I guess what I need is a relay or some form of switch that would only operate when the current rises to this activation threshold at or around 5V.
Can anyone give me any pointers on how to address this?
thanks.
stu
gridrunner2011-04-01 13:29:55
trm
2,877CR
Hi Stu,
Can't advise on the relay solution I'm afraid but I think if you scoped out the feed to the piezo you'll find that when it's triggering it's actually going to be sending some kind of square/sawtooth wave, so you're going to have a problem with the relay also sounding like a buzzer! and the camera getting hundreds of thousands of trigger events.
My suggestion would be to work backwards in the circuit from the piezo driver and find the part which detects a signal from the remote sensor. If it's anything like the wireless doorbell I was looking at over the weekend then I would expect the receiver has an output pin which signals high or low when an "sound alarm" signal is received, as opposed to a dedicated output which directly drives the piezo. Assuming the design is similar to what I'm thinking of, if you intercept the "sound alarm" signal a bit earlier than at the piezo you'll have a normal on/off signal which you can then use to trigger the camera.
cheers
