TECH HELP:Kung Fu Master garbled characters
5,332CR
[ukvac] TECH HELP:Kung Fu Master garbled characters
Hi all,
I recently bought a Kung Fu Master bootleg(a two boardset with the EPROMS labeled from 1 to 8 in the top board and F ,J,K,N,T,3T in the bottom board ).The board is likely modified for other games (some traces are broken on
purpose,some capacitors are added,there are also some jumper wires..)
The board works well except for the characters ,they are all garbled and messed up .The remaining(background,etc,etc..) of the gameplay is good,also the sound is fine..
I'm pretty sure the problem is in the bottom board that ,in my ,opinion,contains the characters EPROMS.Maybe these EPROMS are bad or some 74 TTL are bad???? Are the characters EPROMS in the bottom board?And what they do the remaining EPROMS? The MAME source is not so helpful because it uses different ROM names...
Could anyone with a same boardset give me some suggestions or helps to repair it ?
Thanks in advance
Best regards
DATA Imported from archives: originally posted by briccus (briccus@yahoo.it)
