tech help reqd - Galaxian
4,987CR
Hi,
I've just bought a small pile of old boards (mostly Namco). I also need some help to identify what I've got - but that's another email.
I now have a number of Galaxian boards but there are two pinouts on Wiretap - one being a DC conversion. Bearing in mind I'm using a standard arcade PSU with no -12V, which one should I use?
Any help appreciated,
Cheers,
RobH
eGroups.com Home: http://www.egroups.com/group/ukvac
www.egroups.com - Simplifying group communications
DATA Imported from archives: originally posted by RobH (rob-ed@arkensaw.freeserve.co.uk)
4,987CR
From my limited knowledge of namco galaxians...
The pinouts you're referring to mention conversion of Midway galaxians from AC to DC,
given that my Namco board doesn't even have half of the components that the conversion
talks about and since *my* board doesn't show any particular signs of conversion I
would guess that the Namco board is +12v only. The pinouts appear to be the same in
all other respects.
A safer alternative is, given that +/- 12v would only be used for sound, to ignore the line
completely until you've identified the working/non-working boards.
Given that this is all purely conjecture on my part, I'd check with deja.com for any rgvac
threads on the subject before commiting iron to flux.
Chris
http://www.arcadenirvana.com
Dedicated to the collection, restoration and preservation of classic arcade games.
DATA Imported from archives: originally posted by Chris Ahchay (chris.ahchay@virgin.net)
P-Man
International man of mystery
1,272CR
[ukvac] Re: tech help reqd - Galaxian
I have 2 midway galaxians boards, i've seen a proper namco version of
galaxians, and as far as i could tell from just looking at it, they are
basically the same. Chris, are you sure that the namco board you have isn't
a bootleg?
If you're looking to wire one up, and not sure whether it's AC or DC, check
for the following on the board:
indications that DC conversion has been done:
- big heat sink is missing, other large-ish components de-soldered, at the
edge connector end of the board.
- Check for 2 large diodes if they've been shorted together, and possibly
bypassed the entire onboard AC conversion stage (includes large ceramic
resistor, transistor on heat sink, big fat capacitors etc..)
basically that's about it.
Andy Welburn - A Collector of fine video game antiquities
http://www.willowsp.u-net.com/andy/collected.htm
>> CURRENTLY MOST WANTED <<
ATARI Battlezone AVG and AUX Logic Game Boards
G
Guests
Guest
This may sound like a stupid question but I don't own any Namco boards. Is it common for boards made by Namco to have no markings, i.e. They don't have Namco written on them anywhere ?, Or have the boards that I have seen all been bootlegs ?.
Cliff.
DATA Imported from archives: originally posted by Clifford Poole (xov51@dial.pipex.com)
4,987CR
I have recently got hold of a Galaxian bootleg and it isn't either of the
pinouts that are one wiretap. I can mail them to you if you want.
(it is dc converted)
Ivan
eGroup Home: http://www.egroups.com/group/ukvac/
http://www.egroups.com - Simplifying group communications
DATA Imported from archives: originally posted by Ivan Mackintosh (ivan@rcp.co.uk)
P-Man
1,272CR
dunno..
Of all the boards i've owned, only the early namco boards actually have
'NAMCO' etched into the copper, the later games on System 1 / System 2 and
beyond aren't marked, with a few exceptions, i believe Final lap has great
big NAMCO white writing on a daughtercard on the bottom.
oh yeah, Pacland (1984) has no obvious namco markings...
I do believe that i've seen the NAMCO logo etched into the copper on
galaxians boards..
I have Tank Battalion from 1980, it took me a while to find it, but it too
has NAMCO etched into the copper, at first i thought it was a bootleg
because of a lack of obvious markings.
seeya!
4,987CR
You're right you know, now you point it out it's all beginning to come
clear...
The reason why mine isn't particularly obvious is that the components have
been physically removed from the board - rather neatly too!
As to how you can tell whether it's a bootleg or not, the only markings I
can find
on the board (apart from a big white sticker saying "Galaxians Namco OK") is
the singularly unhelpful "bd1 side1" etc on each of the boards.
Chris
games.
MarbleMad
106CR
I've have a xevious, bosconian, gaplus, and mappy board. All original
all namco and no namco logo on any of them.
My midway galaxian has midway etched on it though.
James G Watt
http://www.kinetic-arts.demon.co.uk
Part of the Video Arcade Game Collectors WebRing.
You are in a maze of twisty little passages, all alike.
-- 20 megs of disk space in your eGroup's Document Vault
-- http://www.egroups.com/docvault/ukvac/?m=1
