TECH: Konami style clone -5v question....
erikthecat
21CR
[ukvac] TECH: Konami style clone -5v question....
> good afternoon?
> i have an Scramble CLONE pcb running via a 'Konami class' finger board,
> powered by a 'prime-power' 104W PSU(swallow electronics supply).
> the board was a known worker on the sellers machine. all other boards play
> ok on the tabletop. other Konami (Sega Frogger) style boards play OK, via
> the same finger board.
> i adjusted the +5v to the correct level, the game plays OK for a while,
but
> then displays misc. sprites all over the screen. after a reset / reboot,
the
> game plays OK for a while, but then repeats the same effect.
> all the connectors are clean and i/c fully seated.
> i decided to check the other voltages,
> +5v terminal reads 5.00v
> -5v terminal reads -4.83v
> is this OK. or could this be causing a problem?
> i suppose the question is, what does the -5v supply / do?
> as this is a CLONE pcb does that require a slightly higher +5 voltage?
> (i'm sure i read that somewhere on a supergun website!)
> should i adjust the +5 level;, so that the difference between +5 level
> and -5 level is equal?
> (i.e, say 5.1 and 4.9 respectively)
> or am i just typing b*****ks? :)
> your help would be appreciated.
> thank you.
> GaRy:)
Jammajup
9CR
[ukvac] Re: TECH: Konami style clone -5v question....
Hi gary
Im sure the other guys will correct me if i am wrong but that sounds
more like a thermal problem or bad game code,leave the board running
for a while and very gently place you fingers (for a short period) on
groups of chips on the board and see if any seem extremely hot!,to me
it sound as if a graphics ram is overheating.
I am not saying that voltages are not important,but there can be a
lot of false alarm in that area.
Jj
http://www.jammajup.pwp.blueyonder.co.uk
P-Man
International man of mystery
1,273CR
RE: [ukvac] Re: TECH: Konami style clone -5v question....
Yes, there are a bank of 2114 ram near to the game roms on the lower
board. After a bit of heatup after use, if you are getting errant sprite
tiles appearing, this is the object ram, I forget precisely which pair
this is, but it sounds like that's where your problem is.
Andy Welburn
www.andys-arcade.com
