Tech: More Centipede
4,988CR
[ukvac] Tech: More Centipede
Firstly, let me thank everyone who responded to my original plea for help
about the tracker ball.
Thanks James for putting up the edge connector information. I was hoping to
run the board off a standard arcade power supply, but I see that it
needs -12v too. So, I guess I can use a PC supply instead. However this
leaves the +/-22v.
So, how has everyone else powered this board - and where can I buy a
suitable power supply?
Alec
Don't know which one to buy? Productopia does.
http://clickhere.egroups.com/click/554
eGroups.com home: http://www.egroups.com/group/ukvac
http://www.egroups.com - Simplifying group communications
DATA Imported from archives: originally posted by Alec Cozens (acozens@tcp.co.uk)
MarbleMad
106CR
[ukvac] Re: Tech: More Centipede
In article <000b01bed3c9$09dcdff0$025704c4@bognor>, Alec Cozens
<acozens@tcp.co.uk> writes
>I was hoping to
You Can!
> but I see that it
>leaves the +/-22v.
Actually you can get away without wiring these up. The 22v is for
storing the high scores. If you miss it out it will not remember your
high score after power off but otherwise it'll work normally. There's no
-12v. The only problem with centipede is the lack of an audio amp and
you can add one quite easily (I've got one wired into my jamma adapter)
or you can make do with rather quiet sound :-/
James G Watt
http://www.kinetic-arts.demon.co.uk
Part of the Video Arcade Game Collectors WebRing.
You are in a maze of twisty little passages, all alike.
Click Here to apply for a NextCard Internet Visa and start earning
FREE travel in HALF the time with the NextCard Rew@rds Program.
http://clickhere.egroups.com/click/449
4,988CR
>>I was hoping to
> You Can!
>> but I see that it
>>leaves the +/-22v.
I already have an amplifier courtesy of Maplins which I use for my CPS2
boards, so that'll do nicely.
Time to give SUZO a ring...
Thanks again,
Alec
