TECH : Mortal Kombat 2 Sound
paul.cawley@clara.co.uk
9CR
[ukvac] TECH : Mortal Kombat 2 Sound
Hi,
I just got an Mortal Kombat 2 sound PCB to go with the main PCB I already had...
I have the 'parallel' cable for it, but not the other one, am I correct in assuming this gets plugged into P3 on the mainboard and gives power to the sound PCB?
Where do I attach speakers? Will it output mono on the standard pins of the Jamma edge connector?
Does anyone have a spare cable for it I could buy (although I doubt it will be difficult to make one - pinouts?)
Thanks in advance,
Paul
5,249CR
Re: [ukvac] TECH : Mortal Kombat 2 Sound
I have a complete board set minus loom that I
want to get rid of, though I doubt you'll be
wanting to buy the whole thing.
Ummm as far as I can recall, it's not exactly a
special wire or it doesn't have anything special
about it, you could probably make one up yourself
for a few quid and a bit of patience.
Justin
> Hi,
with the main PCB I
> already had...
> to the sound PCB?
> Thanks in advance,
> Paul
> [Non-text portions of this message have been
removed]
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
This mail sent through UK Online webmail
DATA Imported from archives: originally posted by Vertigo (vertigo@ukonline.co.uk)
