Tech : Namco pinout quest
LukeWells
334CR
[ukvac] Tech : Namco pinout quest
I need pinouts for the following NAMCO version pcb's
Dig Dug
Super Pac Man
Mappy
I have been on spies, the manual archive etc etc and downloaded several manuals.
One problem i have is ALL the manuals have different pinouts which talk about several molex connects.
The 3 boards i have use an edge connector (22 pin i think?) a 3 way amp lock n mate and a 6 way lock n mate. Why are the Namco pinouts differnt from those in all the manuals?
Any help would be great
Luke
4,058CR
RE: [ukvac] Tech : Namco pinout quest
Replied to this on-list as the existance of the 'unsorted' directory on
spies may not be as obvious as it should be! - think I discovered it
when I mirrored the site, doesn't seem to show it on the actual HTML
page.
I know you said you looked on spies etc, but did you check out the Mappy
document in the 'Unsorted' section?
http://www.spies.com/arcade/unsorted/Mappy.txt
This shows a 22way edge connector, a 6 pin connector and a 3 pin
connector. Quite possibly what you're after. Doesn't specifically
stipulate that it's Namco mind.
Nothing on the others though, sorry!
If you have checked this out and I've got it all wrong then I'll just
crawl back under my rock and ignore me :O)
Cheers,
Guddler.
LukeWells
334CR
Re: [ukvac] Tech : Namco pinout quest
Thanks thats a massive help. That is the mappy pinout i need.
Can anyone confirm whether dig dug or super pac man also share the same
pinouts ..... according to klov they are all different, but then they may
not be refering to the Namco versions
Luke
robotronuk
60CR
The Namco ones are all the same ,
3 pin for power 6 pin for video and the edge connector
for the rest.
I think most Namco boards from that era use the same pinout
eg Sky Kid, Pacland, Gaplus etc etc
Lee
I have a Namco Superpacman and a Namco Mappy and I use the same pinouts for
them. I also had a DigDug but this was the Atari version which is different.
I don't know about the Namco version but it is very likely the same (like
Gaplus, Galaga original, Sky Kid and others).
Marco.
----- Oorspronkelijk bericht -----
Van: "Luke Wells" <luke@arcadeuk.com>
Aan: <ukvac@yahoogroups.com>
Verzonden: donderdag 26 juli 2001 14:46
Onderwerp: Re: [ukvac] Tech : Namco pinout quest
> Thanks
> Luke
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
chuckles1001
34CR
Sorry for bumping this, but I have having the same problem finidng the correct pinouts and the link mentioned here is dead, I am trying to find ones for Gaplus (Namco board) but the I keep seeing thing like Pins E & 5 are not used and up and down need reversing.
My cocktail cabinet was converted a long time ago (using standard RS blocks to main strip and the 6 pin) and some of the wires have come loose but he 3P plug is not used, so wondering if people saying E & 5 are not used are using the 3P plug, where as mine used E & 5 instead, could that be right?
I want to take these RS plugs off and just put a Jamma connection on but want to make sure I get them right and do not blow my board up (this is the first time I have been under a cabinet :()
Attached is the pinouts I found, which say galaga and gaplus are the same :(
