TECH : Outrun Info / Help
paul.cawley@clara.co.uk
9CR
[ukvac] TECH : Outrun Info / Help
Anyone can help me on this?
I plan to attempt to get something out of an Outrun PCB I bought ages back when I am off work next week, but I need some info!
On my PCB are two connectors (one on the lower and one on the upper board) - These are labelled J (upper) & K (lower).
According to the Outrun FAQ, these are power related, but I need to know if they are just a 'bridge' between PCB's, in which case I will just wire them from pin to pin, or do I add the same power inputs to both top and bottom board?
Also, the PSU ground and +5 on the G connector, can I use the same +5 and ground I am running to the aforementioned connectors?
Sorry if this all sounds a bit mad, it is! but I would love to see if I have a working PCB.
Cheers,
Paul
Ordyne
1,282CR
RE: [ukvac] TECH : Outrun Info / Help
All the +5 and ground connectors to J k & G goto your psu..
To power the board up should get away with just J & K
Craig
Outrun
3CR
Re: [ukvac] TECH : Outrun Info / Help
Paul,
Just to work on the PCB you will need to connect 5v and ground to both the
small (10 pin?) IDC connectors that are above each other, plus the video
output.
Cheers,
Kev (Outrun)
