tech pacman bootleg problem
5,323CR
[ukvac] tech pacman bootleg problem
bootleg pacman GDP-01 pcb
it resets just before the rug test pattern (the white hollow squares) comes
up
any ideas
thanks in advance
Mark
DATA Imported from archives: originally posted by Mark (markgwilliams@ntlworld.com)
pobtastic
477CR
RE: [ukvac] tech pacman bootleg problem
Yes, check the watchdog circuit... Hmmmm... If that looks okay I'd verify
the ROM's and check the sockets out. If your HALT signal is on (whatever
way that is, high or low I forget hell look it up) then you're in trouble...
Oh and try swapping those 2114's around if they're socketed and see if you
get a different error (hence meaning one is faulty).
Pobster
pobtastic
477CR
Okay HALT is active low I looked it up... And somewhere on that board is a
74LS259 first see if its hot... And if it is then change it, else if its
cool - check its I/O with a probe. Finally, if its anything like an
original check out the E-ROM's on the auxiliary board.
Pobster
PS. Sorry about the vagueness and ummm... 'quickness' of these emails I'm
going out!
5,323CR
[ukvac] Re: tech pacman bootleg problem
Are you running the Midway Pacman ROMs?
If so, try the Namco ROMs.
The Midway ROMs will not work not work on some bootleg
Pacman boards. There is an important difference between
the two sets of ROMs in the way the interrupts are
handled. I found this out one day and it was a nightmare
to track down.
Gary.
DATA Imported from archives: originally posted by (lists@ntlworld.com)
