[ukvac] Tech: Pacman multigame problem
I thought it was worth reporting this as it might save someone
some trouble...
I have a Pacman bootleg cocktail board (marked OVG-11) that had
been hacked to run Ms Pacman. I decided to convert it to run both
Pacman and Ms Pacman (switchable) by following the guide on:
http://marvin3m.com/video/pacman.htm
After completing the conversion I found that Ms Pacman worked but
ordinary Pacman didn't. I checked my conversion work several times
and it was correct. After some probing I came to the conclusion that
Pacman was crashing on start up. After much head-scratching I ended
up digging into the code for the games and found something important:
Midway Ms Pacman runs in Z80 interrupt mode 1 and Midway Pacman runs
in Z80 intrerrupt mode 2. Mode 2 requires a little bit of extra
hardware (a latch to store part of the interrupt vector). I
checked my bootleg board and found that this hardware was missing
(the Z80 IORQ pin was not connected to anything).
After more digging I found that Namco Pacman runs in Z80 interrupt
mode 1! I burned a new EPROM containing Midway MS Pacman and
Namco Pacman and now I have a working multigame.
To summarise things: Midway Pacman will not work on some bootleg
Pacman boards (unless the code is hacked). If you find this,
try the Namco Pacman ROMs.
Gary.
DATA Imported from archives: originally posted by shepg2002 (lists@ntlworld.com)
some trouble...
Gary.
