[ukvac] Tech: Pmans AR2 doco (LONGISH)
Hi all, as people have been asking a lot of questions relating to AR2's
recently I thought I'd post a copy of Pmans excellent document on AR2
theory, repair, and bulletproofing as it's kinda hard to find on the net.
Hope it's as useful to the rest of you as it's been to me
DanP
************** Start of article ****************
This article is semi-techie, don't worry if you don't understand it,
you don't have to be able to
It gives you an idea as to what games
companies did when re-developing an old idea. Also, my interperetation
of how these things works may not be technically correct, but it fits
the situation, i'm not classicly trained, and therefore do not adhere
to such sensible rules
I just want to get games going again like
you do
Ok, so you've got yer new (old) atari video game, and it doesn't work..
Surprise, surprise.. You've done the neccesary steps to determine that
the fault lies in the Regulator/Audio board (AR2 or AR1). How do you
fix it? well.. first off, there is 2 main types of AR1/AR2 boards
that come in classic era atari videogames, called the AR1 and the AR2.
In the 70's in atari's infinite wisdowm, this job was actually done on
the game pcb itself. This meant the logic PCB could get very hot, taking
actual game logic out with it. The complaints were basically that if the
regulator section did go down, it meant the whole game pcb had to be
removed and replaced.. a costly excercise.. Atari split the section off,
made the game pcb logic do just the game logic and the sub-power assembly
was located on its own board, thus was born the Regulator/Audio board
(AR1/AR2)... This was cheaper and quicker to replace for the operator.
Anyhow, Atari started this trend from Lunar Lander onwards.. Lunar Lander,
Asteroids and Asteroids deluxe (atari's first three vector games) and
Football (4 player) all used the AR1. While audio amplification, and
some voltage regulation was done on this seperate AR1 board, there was
still a relatively large amount of power still regulated on the game
pcb itself (36v AC) which still caused some problems occasionally. After
Asteroids Deluxe, they re-designed this AR1 configuration, by simply
extending the board, regulating the 36v AC on there and piping 22v AC to
the game pcb instead, much better.. This configuration was to prove
so versatile, atari stuck with it from 1980 through to about 1984. From
there it morphed into the AR3, and from there came the 'new' switcher..
but that's a story for another day... lets stick to AR1/AR2.
So anyway, as the time progressed, parts of the AR2 became redundant.
Instead of redesigning the boards, Atari simply omitted the redundant
parts leaving parts of the AR2 bare.
Now, for collectors today that can be a bit annoying. When someone says
they have an AR2 board spare, you often have to try and work out what
revision it is to see if it'll work in your machine
below is a list
of which games used what revision boards, its not complete, but what i've
been able to ascertain :
A034485-01 - Asteroids, Lunar Lander, Football (4 Player)
A034485-03 - Asteroids Deluxe
A035435-01 - Atari board versions of Xevious, Pole Position I + II, DigDug
A035435-02 - Battlezone, Centipede, Crystal Castles, Liberator, Quantum,
Red Baron, Star Wars, Tempest, Warlords, Return Of The Jedi, Arabian,
Black Widow, Major Havoc
A035435-03 - Missile Command, Monte Carlo
A035435-04 - Gravitar, Millipede, Space Duel
A035435-05 - Namco Board versions of Pole Position I + II, Xevious, DigDug
A035435-06 - Kangaroo
Now, you think, why is this important to me?? Well, you might not be able to
find the precise revision for your machine, this is a handy cross-reference.
In all honesty, if in doubt, use a revision -02, if you have one of these,
it will work on ALL of them, and they are the most common
Golden rule?
The later the revision, the more parts they strip off.. with the exception
of the -01 which is the least populated version, no idea why it got the
-01 revision.. When re-thinking the design, certain things were taken into
consideration, cost to produce, pros and cons.. so you find that the
-03 board is actually loaded like an -02 baord but without the numerous test
points... pros.. cheaper/quicker to produce, cons... you can't hook
equipment
onto the test points.. big deal
well.. you say that, because after the
-03,
they went back to using the -02 as operators didn't like the idea they lost
the test points.. the customer is always right eh?
The -05 and -01 revisions may seem a little odd, its the same game, why two
different board versions?? well, those games listed were actually licenses
that atari bought off of Namco (japan). Atari made up the cabinets and
filled
them with either namco boards or their own boards, either to meet demand
quickly when it had a japanese release timed with a european release or what
i don't know
Anyway, some cabinets had namco boards, and some had atari
boards, the namco boards always had the audio amplified on the game PCB,
like the rest of the industry by this point, but Atari insisted that their
version of the board would require external amplification, et voila, one
revision of the AR2 had the audio amp section on it, the other didn't..
Ok, history lesson over... HOW DO YOU FIX THEM?
Well, a lot of people go for shotgunning the entire board, you can buy
'kits',
much like monitor cap kits, which conta
DanP
you do
equipment
-03,
filled
i don't know
'kits',
