Tech : Point Blank 2 kit
[ukvac] Tech : Point Blank 2 kit
Hello,
I have collected a Point Blank 2 kit. The seller told me it was a never used
kit and I must admit it looks brand new :)
I have plugged the jamma pcb in my jamma cab and it works fine. I have also
attached the guns, but they need +24V and I don't have that on my power
supply. My guess is that the +24V is just for the feedback and reload
function of the guns (there is a sort of pinball-part in it, I think it is
called a "solenoid").
My question(s) :
Even without attaching the +24V, should the game respond to the gun-trigger?
It doesn't... :-(
Is it possible that the guns don't work on my cortex-monitor and only work
on certain monitors? If so, can anyone confirm on which monitors the guns
will work?
Thanks!
Marco
5,323CR
RE: [ukvac] Tech : Point Blank 2 kit
Well.. Even if the you can't hit anything on screen when you press the
trigger the screen should flash.. So I guess the next is try hooking up
the +24 :)
Kip
DATA Imported from archives: originally posted by Kip (kip@thedvdproject.com)
5,323CR
Re: [ukvac] Tech : Point Blank 2 kit
marco i have the manual for this game at work
i know that on namco crisis zone that it comes up with a motor error if the solonoid packs up and this can be skipped in test mode
not sure if its the same for point blank 2 i cant remember
i will see if i can find out for you
sticky
DATA Imported from archives: originally posted by Richard MONRO (sticky@stickyk2.fsnet.co.uk)
Hello again,
many thanks for all the help, I am pleased to tell that everything works
fine now although I still will have to attach the +24V for the solenoid
recoils, but it allready plays fine :)
Marco.
----- Oorspronkelijk bericht -----
Van: "Marco Krijger" <originals@chello.nl>
Aan: <ukvac@yahoogroups.com>
Verzonden: woensdag 1 mei 2002 21:14
Onderwerp: [ukvac] Tech : Point Blank 2 kit
> Hello,
used
also
> My question(s) :
gun-trigger?
> It doesn't... :-(
> will work?
> Thanks!
> Marco
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
