Tech: Power Supply
4,982CR
[ukvac] Tech: Power Supply
I just wanted to check the best way to test a linear PS. I hooked it
up to my Multimeter and got 12v and 5.3v after a bit of fiddling with
the trim pot. I then changed to an AC scale and tested again thinking
this would tell me if the filter caps were doing their job. I got 0v
for both outputs. I know I should test the supply under load so can
anyone tell me if a low resistance high wattage ceramic resistor is
what I need and if so what value.
giblet
Was the salesman clueless? Productopia has the answers.
http://click.egroups.com/1/749/5/_/5935/_/948121047/
eGroups.com Home: http://www.egroups.com/group/ukvac/
http://www.egroups.com - Simplifying group communications
DATA Imported from archives: originally posted by giblet (jasong@savcov.demon.co.uk)
