[Tech] Sega System 16 - no inputs working
LukeWells
334CR
[ukvac] [Tech] Sega System 16 - no inputs working
Hi,
I have a sega system 16 board (Aurail) with no inputs working.
I know what the problem is to an extent ... but the solution?
All the inputs go through opto's
If I pulse the output side of the opts then the game coins etc etc
but the input side is not working. It looks like the +5v is missing
from all of the positive side of the photodiodes on every single opto
so there must be something somewhere common to all of them that has
failed? I've tried tracing it out but can't really work out whats
going on and can't find any sega system 16 schems.
Thanks in advance for any help
Luke
system11
9 (100%)
345CR
Re: [ukvac] [Tech] Sega System 16 - no inputs working
Check your jamma adapter - of the four 5v feed pins, 3 are tied
together, and one is seperate. That one feeds the inputs.
james
Luke Wells wrote:
> Hi,
> Luke
LukeWells
334CR
[ukvac] Re: [Tech] Sega System 16 - no inputs working
Solution :)
<Luke[MH]> bad factory soldering on the 5v cap
<Luke[MH]> solder only on underside
<Luke[MH]> not flowed through to top
<Luke[MH]> so bad connection with middle plane
Luke
