Tech: Voltages & 1942 troubles
4,058CR
[ukvac] Tech: Voltages & 1942 troubles
Can anybody tell me what voltages i should be outputting from my power
supply please? I seem to remember that they were all a little over, but i
don't know how much over is okay...
The reason i ask.... i have a 1942 board. Worked perfectly the night before
last for a good few hours (the first night since it was delivered)when i was
playing it by myself. A friend came over last night (obviously jinxed!). It
had been switched on for about 5 minutes, no more. We were playing a 2
player game (on a cocktail cab). Player one's turn was fine, player 2's turn
(mine) went okay for about 20 or 30 seconds when everything but the sound
froze.
I couldn't get the game to do anything, so switched it off. Switched it back
on about 30 seconds later and now all i get is a light blue screen (so the
board/monitor is clearly powered), but nowt else responds. If i flick the
test dip switch and switch it on, all i get is a total garbled screen, where
i should get a nice service menu....
Anybody got any ideas please as this is now ALL my boards have something
wrong with them (all different things) and i'm starting to get rather
dissilusioned by the whole thing!!
Guddler.
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
Share information about yourself, create your own public profile at
http://profiles.msn.com.
d-type
172CR
RE: [ukvac] Tech: Voltages & 1942 troubles
> Guddler.
Welcome to retro-arcade! Wait 'til you get your color XY monitor dying and
your custom ICs blowing up.
You've found the other side of the whole UKVAC scene - that of:
a) finding out how it all works so you can fix stuff (a BSc Electronics
helps) or
b) finding someone else who can fix it for you (having $$$'s or doing
favours helps).
Good Luck!
Phillip Eaton (D-Type/Flip-Flop)
Tel: +44 (0) 1536 504434
Tel2: +44 (0) 1536 268424
Mobile: +44 (0) 7775 726366
Fax: +44 (0) 845 334 8195
Email: d-type@freedomprojects.co.uk
Website: http://www.freedomprojects.co.uk
A
andrewhannay
Guest
Ahh! a fellow engineer
How many Engineers are out there ?
I'd like to know what sort of background
UKVAC subscribers are from.
5,325CR
Re: [ukvac] Tech: Voltages & 1942 troubles
With modern (relatively) boards like 1942 you can put quite a lot
more voltage than the chips specify and still be ok, so dont worry
about that - not enough voltage is a bigger problem, but youve
tested for that and you're ok. 1942 will run fine with only 5v
supplied, so its not a power problem. Looks like the board has
gone belly up - check the conections between the 2 boards - try
some different cables if you have them - make sure they are in
tightly. Other than that - its a matter of fault finding with a logic
probe.
Gav
> froze.
> Guddler.
Gavin Yuill
Dept Of Mining and Mineral Engineering
Houldsworth School
University of Leeds
Leeds
LS2 9JT
Email: mingjy@leeds.ac.uk
Tel : 0113 233 2808
DATA Imported from archives: originally posted by G.J. YUILL (mingjy@ecu-01.novell.leeds.ac.uk)
Okay,
I'll jump in here.... I'm an ex-arcade engineer who has moved onto computers
and bigger things....
I only left that realm of job because
1. Saturdays were part of your normal working week
2. The money wasn't that good considering the hours you put in.
If i could sort those two niggles, i'd jump right back in there now.... It
was my favourite job throughout the eighties and i feel privileged that i
had the chance to work on all those machines that are now part of our
"classics" forum.
Mark Adams
