erikthecat
- Credits
- 21CR
[ukvac] TECHNICAL: mains filters question
evening,
i have a simple technical problem, can anyone help me?
i ordered a 5 amp mains filter, i was going to put it in a homemade cab to protect a tv monitor and a JAMMA psu.#
the problem is that a 2 amp filter turned up!
is that any use?
could someone confirm how many amps a JAMMA psu uses.
the sticker says on the psu 220-240 1.3A, so i suppose that's 1.3 Amps then
the monitor says it's 240v and 68 W max power consumption.
is that W=VxA, A=W/V 68/240= 0.238A
if i add 1.3 and 0.238 that equals 1.538A which is below the 2A printed on the filter,
does that means i can use it, as long as the load is not increased in any way?
or do i require a larger safety margin?
what happens if a filter is overloaded? does it just stop working? explode? sizzle a little?
i hope someone can spare the time to reply,
thanks for your time.
GaRy
evening,
is that any use?
GaRy
