tekken 2 connections
Gaming Heaven
106CR
this is probably the dumbest question in the world but I am not used to Jamma
I got a tekken 2 pcb which I thoght was jamma, the main jamma connector just about fits but not bang on, I powered up but nothing from an apparently working board
but there is another edge conector on the pcb not used
is this a pure jamma board or something else?
thanks
mathj
499CR
the extra connector is for the extra kick button harness, board should work just fine without it but you will be missing 1 kick button per player
math
Gaming Heaven
106CR
thanks for info
its running in a Goliath with 3 actions buttons per player but I don't think there is anything else to connect inside from the Goliath.
I will recheck my connections but board might be dead, I will check for onboard LEDs
so tekken 2 has 4 control buttons, yes that makes sense, like a PS1 controller for the ported version?
Gaming Heaven2015-11-11 23:19:41
segaarcade
118CR
for sure you dont have the smaller connector in your cabinet. it is a namco-style kickharness connector. on the longer jamma connector you will only get the 2 Punch Buttons each Player. the 2 kick-Buttons each Player you have to grap from this smaller connector. pinout is online!
