Tekken 3 PCB won't boot
Devil_Mish
87CR
Hi,
I previously created a topic where my Tekken 3 board wasn't booting. The verdict from that were there appeared to be some bent pins on the Sony chips.
So I bought a new board, also supposedly fully working, plugged it in and had the boot loop issue same as before where you can hear the 'good morning' sound being cut off and repeating... But now again I have nothing.
Surely I can't have 2 supposedly working boards break on me? Jamma readings are 5.08v and nothing seems odd about the board itself.
http://imgur.com/a/xbSG2wf
Any other suggestions?
Thanks!
tb2000
3,584CR
Just wondering, have you tried a different PSU? It may say the 5v line voltage is OK but if you don't have the amperage it may also have an effect.
Devil_Mish
87CR
Thanks Dave, can't see any other bent pins and voltages seem stable at jamma side.
I haven't tried a different PSU but the one in is brand new so I'd be surprised if it was that, other boards run fine too annoyingly!
TheDaddy
14 (93%)
7,230CR
I would throw another jamma pcb in to confirm all working and if it is then maybe you are just unlucky and you do have 2 faulty boards. Sounds like the current one is resetting - hence why i thought voltage. Also as mention sometimes psu will show fine and only goes wrong under loan. I would offer to test it for you if you like ? You would have to pay return postage though.
Not sure what else to suggest.
Dave.
Devil_Mish
87CR
Thanks for the suggestions and the offer Dave!
Might cut my losses and sell them not working on the forum to someone with more experience than myself.
Cheers all!
Mc-Q
1,450CR
for some reason, people treat these psx based boards like sh*t.
i have about 7 - maybe more.
*all* of them had broken-off capacitors and/or bent pins on the top board.
most from different sellers too.
